Thread: where is my oil filter
    Apr 2008
    murton seaham
    Default where is my oil filter
    as above ive just had my 150 cdti serviced and got home to take a look and found oil all over cover and down front of engine and whot i thought was the oil filter not changed am i right in thinking that the one at the back of the engine below the fuel filter is the oil filter thanks in advance (pic would be nice)ta
    Regular Member DavieVectd120's Avatar
    Washington
    Quote Originally Posted by tonyord View Post
    The filter is at the back of the engine above the O.S drive shaft and point's to the gearbox it has a 32mm nut on the end.
    It may be that they have spilt oil when doing the service.
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Only the oil filter element is changed on the vectra, i.e inside the cannister that you can see. So it won't look any different.
    Apr 2008
    murton seaham
    is this white filter the oil filter sorry about pic quality
    Jan 2008
    Paisley
    Pics pretty small, but that is for power steering. It's easiest to see the oil filter housing from underneath the car, although not if the cover is back in place. The oil filter housing is black in colour
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You cannot change the oil filter from the top. its at the back of the engine IN THE MIDDLE AND POINTS DOWNWARDS!!, IT HAS A LOCKING CLIP ON IT TO STOP THE TOP FROM COMING UNDONE, you have to hold the clip away with a screw driver and undo the filter lid till it passes the clip!, there's a little drain pipe on the side of the casting put a length of garden hose on it long enough to drain the cannister contents into your tub. ((marked in red square in pic.))
  1. Oil filter
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:40
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Air filter
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 13th July 2009, 21:17
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
