Thread: Shudder and smoke
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default Shudder and smoke
    Right, I may have some potential problems.
    1. I've started to notice a slight shudder from the car from side to side when accelerating. Any ideas?
    2. Complete seperate matter, the car blows out a mass of blue smoke on start up but the oil level hasn't changed at all. A potential issue somewhere?
    2.0 DTI 52 plate
    Ben
    Regular Member eaglepva's Avatar
    Up North
    You could try cleaning the egr valve out and also do the manifold while you are their as they get full of ****e.
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Motion like that in my experience would be a bush on a wishbone , bent steering rack or failed engine mount. Jack up the car and hold the wheels at the side and check for play then do the same holding top and bottom. Next take if the wheels and visually check each bush and joint then use a pry bar carefuly to push against each component looking for any play. Whilst the car is up take off the undertray and check bottom and top engine moountings for play.
    Good luck bud
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Could be turbo seals on the way out, but one to watch for on the 2.0 DTi's is loosing oil with no visible trace, it has been known for the injectors to fail in such a way that engine oil gets returned to the fuel tank via the injectors (They use engine oil pressure to actuate) and you end up burning it, your exhaust will have a blue tinge to it all the time and the car will run a bit rougher than normal.
    It's not uncommon for turbo's to start to leak once they've done 50k miles but it's also no immediate reason to replace it either unless your throwing loads of blue smoke out whilst accelerating, I would keep an eye on it for now.
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    thanks for your comments. got some investigations to do!
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. Shudder / egr
    By amir2300 in forum Engine & Drivetrain
    Last Post: 15th September 2011, 23:10
  3. Shudder
    By Taxi_G in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 11:20
  4. 2.2 Dti shudder and smoke problem
    By signum_jon in forum Engine & Drivetrain
    Last Post: 4th February 2011, 23:20
  5. Shudder at just above 30 mph
    By Rodnoc in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 21:31
