Thread: Signum 2.0 dti fault codes
    ashford,kent
    Default Signum 2.0 dti fault codes
    hello
    i am hoping someone may be able to shed a bit of light on the two error codes i have had come up on my ecu, one is the T0638 code which i have read some bits about it but not too clear on what it could be.
    the other code i have on my ecu is t0234, according to the garage this can either mean a split hose, the wastegate valve or the actual wastegate,
    My signum has only done 100k is it a common problem for the waste gate to go??
    any help on this would be a huge help as i don;t want the garage to rip me off
    West
    Do you mean P0234 & P0638 ? as i'm not familiar with tcodes.
    my first thoughts are:
    check all vac tubes & connectors for splits & or make sure they're connected properly along with check the pumps are also working... these are common on all dti engines
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    my first check would be all the small vacumm hose rubbers and also the big boost hoses
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Po234 is boost pressure control circuitpositive deviation
    Po638 is throttle control circuit negative deviation
    as above with checking for split hoses especially the connectors on the small vacuum hoses .
    po234 is telling you have a faulty boost pressure sensor , or what is generally the case it is covered in crud from the manifold which is stopping it working , remove and clean with carb cleaner should see it resolved ,follow the how 2 for guidance.
    po638 again relates to exhaust manifold that houses the sensor remove the manifold clean out with carb cleaner should see a vast improvement .
    while your there you might as well clean the egr valve as well as the faults above are often linked to choked egr as well , there are numerous thread on here showing you how to clean egr valves for dti engine ,s along with guide,s for the other fault,s
    ashford,kent
    thanks for the comments, as i have no idea on how to take the engine apart even with the how too's its going back to the garage on friday, just a bit worried as the bloke is getting someone else in to have a look at it as he is not that well up on fault codes so i am going to take this info in with me and get them to check them bits first fingers crossed it doesn't cost me a samll fortune !!
    Thanks again
  1. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  2. 2 Fault Codes
    By fattony in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 20:06
  3. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  4. 2 fault codes
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 12:49
  5. Sick Signum 2.2 Direct (Fault Codes)
    By kaston in forum Engine & Drivetrain
    Last Post: 13th September 2007, 10:31
