Results 1 to 10 of 23
Thread: ECU Remap Failure - Car Won't Start - Stuck!!
    vectra_sri_failure
    Guest
    Default ECU Remap Failure - Car Won't Start - Stuck!!
    Well being a numpty I opted for the 'at home' convenience of remapping my car which has gone horribly wrong.
    I won't say who the remap company is because I'm hoping a call to them tomorrow will sort all of this out but it's my fault for doing this out of hours at work!!!
    Anyway, car was read successfully, I saw my VIN - engine number etc etc and then chose my map. Wrote successfully to the device, connected it to the car - all went well flashing happily then WAM, started flashing a red light. I left it for the required time and nothing - connected to PC and it said failed reflash (duh!).
    So, tried again and it wouldn't write. So, started fresh and now it won't even read my ecu details just starts then flashes red again!
    Has this happened to anyone and I'm hoping it's not completely fubar'd!
    My car won't start and I've tried d/c the battery and nothing still fails to read ecu now.
    I also have F Miles on my readout!
    If anyone is doing a remap at home I would hold off if I were you!!
    West
    Sounds like you may have spiked the ecu
    Surrey
    Oooopps,that will be costly
    Leicester
    Vectra C management should not be messed with unless you know what you are doing. Some tuners sometimes have trouble writing to Vectra C.
    You very well may need a new ECU.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not sure if the OP maybe means a BSR PPC or a Superchips Bluefin type device
    vectra_sri_failure
    Guest
    Exactly! I've looked around and I think I can get a repair file for my car so will ring the place that sold me it tomorrow and I've also emailed the manufacturer of the device too.
    Failing that a trip to VX may be required for them to re-flash it if possible....
    How much is a new ECU if worst comes? Please?
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    About £600 or so
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    vectra_sri_failure
    Guest
    Quote Originally Posted by plasma View Post
    About £600 or so
    Well here's hoping that it's not going to be fubared!
    Is there a vaux-com / opcom legit device that can put me back on an ECU standard map?
    Failing my IPF device being able to do it.
    I've got the carpass and everything etc
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I don't think the BSR PPC ever gives a choice of maps, the appropriate map is supplied with the PPC unit & if it isn't compatible the existing map is copied to the PPC, sent to BSR over the net & a suitably modified map returned to be loaded back onto the car - does the Bluefin give a choice of maps? I'm fairly sure the Regal IPF gives tuning options
    edit - guess it is the IPF then!!
    vectra_sri_failure
    Guest
    Quote Originally Posted by Ian S100 View Post
    Wooooops!
    Yeah it is! Lol.
    Just got to sleep on it tonight, not a lot I can do till tomorrow as car is at work stuck in the carpark!
    Hoping that I can get it back up with a forced standard map with my security code etc
  1. Failure to start
    By dunc2610 in forum Y & Z30DT Specific
    Last Post: 29th October 2012, 14:37
  2. 2.0t remap from remap science bradford
    By stefan7153 in forum Petrol Engine related
    Last Post: 4th May 2011, 22:03
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. HELP, stuck on A14 18:55 12.05.09
    By chrisf70 in forum Engine & Drivetrain
    Last Post: 15th June 2009, 16:28
car wont start after remap
vectra c wont start remapping
backup vin ecu ipf
ipf tune vectra backup
remap car wont start
z30dt wont take remap
ipf unit failed to flash now car wont start
tractor wont start after remap
vectra c remap not start
vectra c 1.9 remap wont start
