Thread: Kitchen radiator question...
    Full Member izonoky's Avatar
    Aug 2007
    London
    Default Kitchen radiator question...
    Kitchen radiator has sprung a slow leak, it's an intermittent drip at the moment, I can't get to the leak or even see the hole, so I've opted to swap it for a new one. Before I drain it, will turning off the mains water and boiler be enough to prevent any overflow?
    2.2 Direct SRi
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    you will still have the water in the radiator unless you drain the system failing that shut both valves on either side of the radiator and disconect valve from radiator and catch water in a basin
    how to here also
    http://www.diydoctor.org.uk/projects...a_radiator.htm
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Aug 2007
    London
    boiler and mains water off too?
    2.2 Direct SRi
    Edinburgh/outskirts
    Mileage : 38000
    dont need to
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Leave the boiler off yes, just to prevent it heating up. Your mains water won't need to be turned off
    Aug 2007
    London
    ok chaps, many thanks, wish me luck
    2.2 Direct SRi
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if you can't get the exact size red to replace it with you have 2 option's...
    1, you can get a slightly smaller rad and get extension pieces of about 50mm for each or 1 side to assist in fitting..
    2, you will have to drain down the system and adapt the pipework to suit the new rad, this can be a real ball ache and if a gravity system then re-filling can be a slow job, if combi boiler make sure the filling loop is in working order, if you think you are going to get stuck with it call a plumber in as the system will prob need a top up of chemical's in it
    HTH
    Midlands Mod Shop - NFFC.
    Aug 2007
    London
    Quote Originally Posted by ditchp View Post
    HTH
    I can get the exact same size, no probs there. It appears to be a common size 800mm (L) x 600mm (H)
    2.2 Direct SRi
    Wales
    Dont forget to add that inhibitor stuff if it hasnt been done in the last 5 years or so.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Kitchen
    By ed taylor in forum General Chat
    Last Post: 10th June 2012, 20:56
  3. Radiator drain plug question
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 20:41
  4. Having a new kitchen
    By djr69uk in forum General Chat
    Last Post: 10th March 2010, 21:40
  5. from kitchen to car
    By vectra 2.0 t in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2006, 22:29
