Thread: Arcing in bulb holders
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Default Arcing in bulb holders
    Hey everyone.
    I have done a search but can't find anyone with a similar problem.
    I have had intermittant bulb failures in the rear light clusters so I pulled them off for a good look.
    It is apparent that there has been some long term arcing accross the bulb to mount Connections leading to pitting burning and one connection had blown a hole through it's mount !
    I have sanded , tack welded and ground repairs to the clusters but was wondering how to stop this recurring?
    Anybody else had this problem and know of a cure ?
    WGAF#5
    its obviously been a bad connection initially thats caused the issue - providing you have rectified this then you should be ok
    Jan 2010
    Blackburn
    Cheers Dez , I hope nothing recurrs.
    Ive never used Vaseline (ooh err) but would this assist the contacts and stop any potential arcing ?
    WGAF#5
    indeed anything that would increase the connectivity and prevent an arc ocurring would help
    do you have some handy
    Regular Member madman's Avatar
    nottm
    ive noticed this only this week after gaining access to all my rear bulbs. the bulb holder is burnt and pitted and the retaianer is pitted slightly. ive tried sanding them down but will vaseline/grease help in any way
    WGAF#5
    white grease (similar to vaseline) is now commonly used in "preventative repairs" on electrical connectivity on harnesses and bulb connectors in the motor trade (to prevent arcing and possible thermal incidents!!) on some connectors its srynge packed into the joints
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would be checking to see if the light fitting isnt leaking normally in the vx world corostion/ pitting/arching in a light normally means water has been present ....the old vec b had it bad some times ...
  1. Vectra c bulb holders
    By shaun.b in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 10:32
  2. H.I.D bulb holders
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 20:36
  3. hid bulb holders
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 02:28
  4. anyone got any spare 501 bulb holders??
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2010, 01:39
  5. H.I.D Bulb Holders
    Last Post: 30th June 2010, 21:53
