Thread: Strange clicky clunky noise when pressing brakes
    Jan 2010
    Liverpool
    Default Strange clicky clunky noise when pressing brakes
    I've started getting this wierd clicky clunky noise when pressing the brake pedal.
    The sound appears to be coming from the rear end.
    I'm thinking the noise could be the brake pads gripping the discs and moving slightly in the calipers?
    Has anyone else had this problem?
    I swapped all discs and pads about two weeks ago and swapped the arb bushes, droplinks and rear upper arms last week.
    Mileage : 000
    Did you put any "anti rattle" plates back in as well as the pads.I have known pads to be loose in the caliper before though.Also did you put "copper grease" on the back of the pads.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Will be as you've said brake pads moving in calliper
    Irmscher Insignia CDTI 130
    Blantyre
    Jan 2010
    Liverpool
    Quote Originally Posted by ed taylor View Post
    The rear pads have the clips that hold the inner pad to the piston. They were fitted correctly using this. I didn't have any anti rattle plates.
    Theres plenty of copper grease on the back of both pads in each caliper.
    Quote Originally Posted by spennny View Post
    They're not VX stuff, no.
    Mileage : 000
    As they are not VX then that might be why you are getting the rattle. As they might not be made to the same exacting standards.
    Jan 2010
    Liverpool
    I guess so. Its strange as it didn't do it straight after they were fitted. I replaced the rear discs and pads on the Mrs' Vectra and I'm sure the pads are the same. It doesn't seem to do it in hers.
    I'll just have to live with it for now.
    Thanks chaps.
    Sep 2010
    liverpoool
    i seem to have the same problem, mine makes a loud click noise on the front when brake pedal is pressed slowly. but if u press them hard no noise. also when i go down an uneven road theres a rattle coming from the f/o/s wheel. i have just replaced all the discs an pads . and the car passed its MOT yesterday.
  1. Clunking noise when pressing accelerator
    By thegoldenbullet in forum Engine & Drivetrain
    Last Post: 17th July 2012, 20:48
  2. clunky springy noise
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 08:50
  3. problem with a peugeot-clunky noise
    By porthy-t in forum The 'Off Topic' room
    Last Post: 29th May 2009, 10:03
  4. clunky brakes
    By craigbarlow18 in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 16:57
  5. brakes,strange feel
    By kpf1grandprix in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2008, 15:15
