Results 1 to 10 of 20
Thread: vectra c indicator fault please help
    Regular Member SRIDAN's Avatar
    Out in the Estate
    5 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Default vectra c indicator fault please help
    Hi
    I have a 2003 vectra 2.2 sri and last night I notice the osf indicator was staying on but not the side repeater or the rear indicator have replaced the bulb and cleaned all the connectors but still it stays on if I put the hazards on the bulb just goes brighter and dim but won’t go off now I have disconnected the bulb, everything else is working ok can you please help.
    Danny
    1st read the manual The vec uses another bulb/lamp if one fails. Double check the side light on the side that your indicator is staying on. Odds on its gone or the connection is bad.
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    You sure you've not got a blown sidelight bulb... the indicator comes on to take over the job until the sidelight is replaced.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    even a slack side or signal bulb can do this
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    Default bulbs ok
    Thanks for your reply,the side light bulbs are all ok and i cleaned the conn,i was out there and now when i sig left the o/s flashes and if i cancel it stays on again?
    If it stays on it thinks the side light - the small 5w lamp - has failed. Try changing these again.
    You didn't fit led's in there did you?
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    Also i unpluged the plug to the headlight and the green/white wire that is for the incator has a constant live but it shouldnt it should only flash as the bulb should?
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    i fitted two new bulbs please see my new post No led fitted
    Right, if the car thinks the side light has blown it uses the indicator in its place. Double and triple check the side light lamps. Change them anyway - just in case.
    Edit: you fitted new indicator or side light bulbs?
    Out in the Estate
    5 Post(s)
    Trim : Leather
    Mileage : 80,000
    ok i will look now and let you know in a few minuts
  1. Indicator Fault
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2013, 23:50
  2. vectra c 05 2.0dti indicator fault
    By cavie in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2011, 17:49
  3. Indicator fault
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2010, 16:29
  4. Fault indicator.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 20:42
  5. Indicator fault
    By Sp33dy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 03:34
vectra c indicator problems
Why does my rear indicator stay on vectra cwhy does my vectra c indicator bulb stay onhow to test rear indicator on a vectra cvectra c indicator comes on with sidelightsvauxhall sri vectra 2008 indicator faultVectra c rear indicator problemvectra indicator problem
