Results 1 to 10 of 17
Thread: Looking for a guru on Astra's lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Looking for a guru on Astra's lol
    I am trying to get to the route of a couple of problems on a 2001 Astra G 1.6 8v
    The speedo has died after alot of fluctuations, which I have pinpointed to a faulty nsf wheel speed sensor (non abs car)
    The car is also cutting out when slowing down to junctions, is this related to the ecu getting strange signals from the wheel sensor? The spanner light comes on sometimes too
    Any help appreciated
    TBH i understand the Vec's better than this damn thing
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    go join an astra forum lol ;p
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Lol i've been searching through them and found loads of posts about the same problem but no-one ever follows up with if its fixed
    18 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    ohhhhhhhhhhhh bummer
    Full Member Big Sig's Avatar
    have you cleaned the TB?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not yet although I had read that that and the EGR valve could be at fault. I am changing the speed sensor tomorrow so if that doesn't cure the problem then that will be the next port of call
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Could may well be speed sensor related John had this on corsas.. if this doesnt cure it remove the throttle body and give it a good clean you will see a small hole in the TB it will be choked sold with carbon deposit build up..best bet it to drill it out with a small drill usually clears the problems..although just reading back your post its mainly 16v's this problems on.. EGR is common on the 8v to
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Dose View Post
    Cheers bud, i'll report back tomorrow about it
    Regular Member RobW's Avatar
    Tain - Easter Ross
    A quick scan on AOC suggests it could be a few things, dodgy ICV, knackered ECU or poor compression!
    Soeone changed the fuel sender which helped a little and someone randomly said the knock sensor but that would only be when under load?
    In my limited experience, I would also check the coolant temp sensor.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    The car needs to know what speed its doing as it thinks its not moving due to your wheel speed sensor fault, Change your hub and i think all your problems will be solved...
  1. Replies: 0
    Last Post: 4th July 2011, 18:16
  2. Guru
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 9th August 2009, 18:04
  3. im a guru
    By big rich in forum The 'Off Topic' room
    Last Post: 19th March 2009, 19:36
  4. a black astra's rolling road
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2007, 19:57
  5. astra's indicator
    By simon5800 in forum General Chat
    Last Post: 23rd June 2007, 23:11
