Thread: Steering gaitor
    Glasgow
    Default Steering gaitor
    guys, my MOT is due in may and i noticed my gaitor is split on my steering rack, no grease at all thier not sure if thier is meant to be or not but would this fail an mot? or if it would fail can i just get new gaitors as the steering works fine?
    Thank You!
    Glasgow
    any one?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Would have thought there would be some grease in there. It is an mot failure i'm affraid but you should be able to buy the gaitors on their own
    Glasgow
    can any one find out for me? ive tried searching but dont see anything, i really cant afford a new rack when it seems to be working fine!
    Glasgow
    No one?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Best to ring dealers mate or local MF and ask
    Irmscher Insignia CDTI 130
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Aug 2009
    on the hills
    hi twaiter, the boots are not difficult to fit, did mine last year for mot,
    firstly give the thread by the track rod end a good glean with a wire brush then slacken the locknut thats secures the t/r/end to the rack, then remove the nut from t/r/end to the hub carrier{before you take the nut off give a good hit with a hammer to the taper to allow the joint to seperate} the unscrew the t/r/end and count how many turns to the end of the rack, this must be done so the steering alignment is the same when you refit the t/r/end, when the t/r/end is off you can take the boots off by splitting the small soft metal clips with a chisel then slide off the boot and refit the new ones, rather than fitting metal clips i used plastic cable ties which are just as secure, then refit the t/r/end again count how many turns so as to keep the correct length for steering alignment. the grease is behind the seals in the rack so no need to do anything. it may be advisable when the job is done to have a the steering track checked at a garage to make sure its is correct then you will not get uneven tyre wear, it took me less than an hour to change both boots, good luck
    Glasgow
    Fantastic guys, thank you very much!!!
  1. Steering rack gaitor leak?
    By silver-tongue in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2010, 19:40
  2. Gear Stick Gaitor Plastic Surround
    Last Post: 5th October 2009, 10:49
  3. new gearstick gaitor
    By jamesr in forum Styling
    Last Post: 8th July 2007, 23:25
  4. Vectra-c.com gearstick gaitor
    By jamesr in forum Parts for sale
    Last Post: 7th July 2007, 22:30
