Thread: Sump plug spline or star socket Size
    Regular Member CBag7's Avatar
    Apr 2009
    South Glos
    Default Sump plug spline or star socket Size
    Hi
    I have a 1.8i petrol 2002 Vectra C and wish to do an oil change, I have a Haynes Manual and it is saying to use a spanner to remove the drain plug but after going under the car to undertake the job I have discovered it is a spline or star type fitting.
    Does anyone know which it is and what size as I need to go buy a socket from Halfords to be able to do this little job.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Its a Torx fitting, a T45 if i remember correctly.. You can change it for a nice proper hex sump plug from Halfrauds when you do the job. I use T34 torx socket from Halfrauds for the job.. becareful to have the T45 in straight so as not to round off the fitting.. Because these can round off is why i say use a normal hex plug with a new brass washer (some use rubber oh er)
    Regular Member LADmachining's Avatar
    Hampshire
    You have to be trying very hard to deliberately damage a torx headed bolt. They are specifically designed to resist camout/alignment damage if the correct bit is used. The only time I have ever seen damage to them is if someone tries to use an Allen key on it instead...
    Also, the rubber 'o'-ring requires much less tightening torque than a brass washer to make a good seal with the sump and prevent leaks. Despite this, some people still do them up to about 10,000 ft/lbs.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    for some reason i typed T34 in post 2, i don't know why, i meant T45.
    Feb 2007
    North west
    whatever they use on a sump plug some grease monkey uses a 3ft breaker bar to put so much torque on the next person to try and remove it fails. IIRC sump plugs are about 20 lb / ft torque. They dont need to be tightened like wheel nuts.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    yep T45 changed mine saturday
    Bishop Auckland
    Default petrol engine sump plug.
    get a new one before you start.splines strip very, very easy.don`t overtighten.
    Cheers[/quote]
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    as stated above, its a T45, just another socket to buy and add to your collection
  1. What size is the Glow plug Socket?
    By GrizzaVision in forum Engine & Drivetrain
    Last Post: 20th April 2010, 20:54
  2. 1.8 vec sump plug torx size?
    By Morephun in forum Engine & Drivetrain
    Last Post: 4th April 2010, 14:06
  3. what size glow plug socket
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 09:33
  4. Help please: - what size plug socket
    By PeterVV in forum General Chat
    Last Post: 24th February 2009, 20:41
  5. 1.8 sump plug T size
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 00:25
vectra c sump plug size
vauxhall vectra c sump plug size
how to drain oil on vectra 2006 size
what size socket insignia sump
vectra sump plug size
4.5 mm torx for sump plugvectra c oil sump plug size1.9 diesel sump plug torxsize of a opel astra 1.9 diesel sump plug washerwhat size is the Allen key size on a vauxhall corsa sump tools required oil changevectra 1.8vaxhaull vectra 08 sump plug sizevauxhallmeriva b sump plug size socket sizevauxhall astra sump plug sizevectra c 2.0 diesel glow plug change tools neededsump nut and wrench for vauxhall meriva 2010vauxhall vectra c sump socketvectra drain plug washer2005 astra 1 8 sport oil sump socket sizechanging oil on 03 20 deisel zafira sump plug sizewhat tool to remove oil drain plug on vauxhall vectra cvauxhall zafira sump plug o ring sizeopel vectra b 2.2 dti sump bolt sizevauxhall vectra c sump plugvectra c drain plug torque
