Results 1 to 10 of 15
Thread: Air con condensor - DIY replaceable??
    Regular Member RLFH470's Avatar
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Default Air con condensor - DIY replaceable??
    Hi all, I hope this is the right section as the actual air con forum is inaccesible to me for some reason. Whilst fitting front parking sensors I saw this on my air con condensor. As this probably confirms what the dealer said and the condensor is in fact leaking, is its replacement a DIY job? Many thanks.
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi mate its very easy to change
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Just make sure the seals aren't leaking.
    WGAF#5
    you should be able to replace it - but make sure you know what your doing as freon from the ac system is a caronagenic and as such all dealers and technicians are now undergoing retraining for new legislation coming into place this June on safe handling so make sure its empty before you start playing
    are you going to replace the unit then get it regassed somewhere ?
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Cheers for that. I may give it a go then as I don't really want to pay the dealer £450ish.
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Sorry, our posts crossed. Yes I would get it regassed professionally. Don't know what to do about the remaining gas. Is it possible to safely run the air con until all the gas leaks out?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    mine needs replacing too, just deciding if I should do it myself or pay £90 to have it done (will have to buy the condensor @ £125)
    WGAF#5
    Quote Originally Posted by RLFH470 View Post
    its dependant on how much gas is still present - as the system is pressurised if it drops below a certain level the the compressor wont engage - but there could still be quite a bit left - the system needs to be evacuated - this is normally part of the proceedure on regassing
    so if your going to get it regassed ask the garage if they can ensure the system is empty - replace the parts - then take it back for a regas **ensure they pop some uv dye into the system as well on regassing as this will make it easier to identify any future/further leaks from the system with a uv lamp and special goggles= just like CSI
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Many thanks for that. I'll definitely have a good think about DIY replacement. Time to hit the web for the bits. Cheers.
    Regular Member P3tchy's Avatar
    Milton Keynes
    Is yours a CDTI or petrol.
    The reason I ask is my AC condenser looks the same but it was in fact the intercooler that had popped.
  1. steering wheel badge -replaceable
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 06:27
  2. Air Con Condensor
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2011, 20:08
  3. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  4. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  5. steering wheel radio controls - replaceable?
    By mark_w in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 22:19
