Thread: Water accumulates in sill
    Regular Member amos's Avatar
    s,wales
    Default Water accumulates in sill
    Just had mine done they done holes on the door seal of the body not seals on the door is this right.
    Technical Service Bulletin
    Ref. Number 09-FR-49
    TIS/TSB Ref. Number E0002540
    Group A-10
    Release Date 04/09/2009
    Door Sill - Water Accumulation
    Vehicles:
    Insignia 2009-Onwards
    Insignia Sports Tourer 2009-Onwards
    All Engines
    Complaint:
    Water accumulates in sill area of front and rear doors.
    Cause:
    Poor fit of sealing clips allows water entry.
    Production
    Modified weatherstrip in production as of VIN WOLGM67C191115427.
    Remedy:
    In case of customer complaint apply additional drain holes (diameter 5 mm) into weatherstrip
    Check in door below window glass if the weatherstrip clips are tight. If the weatherstrip clips are loose or can be pulled out easily, replace the clips.
    Leicester
    Mine does that, I'll get it done when it goes in next week for the centre console re-work.
    Regular Member kpf1grandprix's Avatar
    luton beds
    had mine done a while ago,,but there is still an amount of water accumilating
    Mar 2007
    North East
    Must admit I've not had this problem with mine and it's an early 2009 model.
    Leicester
    Mine was built around Jan/Feb 09. Doesn't do it all the time, but more often than not.
    s,wales
    Has any one had this done, my dealer has put holes in the seals around the door opening of the car not the lower part of the doors
    Regular Member grumpano's Avatar
    North West
    I dont seem to have that problem will keep an eye on it.
    Thanks for the heads up though.
    Regular Member wise1's Avatar
    Jan 2010
    essex
    no problem on mine either but I will look out for it
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    estates only i think
  1. Sill protectors what do you think?
    By TopRod in forum Styling
    Last Post: 10th November 2011, 09:47
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. Replies: 9
    Last Post: 26th November 2007, 22:26
