Thread: Kitchen laminate worktop water ingress
    Regular Member Boy Lard's Avatar
    Derby
    Default Kitchen laminate worktop water ingress
    Hi guys
    Need some help please.
    At home we've evidently had some water get down between a joint in the laminate worktop and has started to lift/bubble slightly either side. Short of having the whole tops replaced, is there anyway of repairing it?
    As a short to medium term solution to stop it getting worse should I run a bit of silicon over it?
    Thanks in anticipation.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    In a word....nope...the interior of the surface is basically like weetabix...been there/complained to ikea n got replacements...
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Is this not the kind of thing your home insurance should cover?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    as said once water gets in they will only get worse............silicon,if there is a gap in the joint ....but eventually it is new worktops i'm afraid
    Derby
    Dammit!
    WGAF#5
    yoo can try and remove the moisture with a tea towel and an iron over the top = but dependant on the laminate finish and its temp resistance if you over do it you will do more damage than good....
    as said a sealant and then pop something over the top to cover it up
  1. Potential water ingress area for saloon owners!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 17:23
  2. Water ingress
    By ianmcv in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 21:53
  3. Saloon boot water ingress
    By MadOnVaux! in forum Bodywork & Interior
    Last Post: 6th February 2009, 18:53
  4. Good news - my water ingress
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 18:09
  5. Water ingress in the footwells
    By michal.lukasik in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 18:25
