Thread: What's tech 2?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Default What's tech 2?
    Hi, more used to low tech cars 1979-1986 until my Omega. Vectra something else altogether, working my way through "How to" lists.
    Noticed one said if you have the blue connector behind centre dash blank traction control can just involve fitting the switch.
    Thought I might be in luck as SRi XP has it, so SRI might be wired. Checked and I have blue connector under alarm slot.
    Seen Tech2 mentioned a fair bit with electrical changes, what is it and would I need it done?
    Full Member Penfold101's Avatar
    Tech2 is the computer system Vauxhall use to access your car's electronics. Due to the Canbus (click here for explanation of that) control systems used your car is more like a computer than a proper electrical circuit and as such there's a lot more it can do, but this means that adding stuff into it isn't simply a case of finding a 12V supply and an earth.
    The Tech2 system is about 2-3 grand's worth of kit and apart from a few select people on here, only Vauxhall will have it. It allows activation of all sorts of extras on the car, fault diagnosis in real time, fault code reading etc...
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Ok, I knew modern cars had more computer like set up, as you say, has downsides as well as advantages. Wasn't aware it had gone that far. Apart from a traction control switch, the "how to" for connecting the passenger side rear fog, and xenon dip beams, I have no plans for changes to the electrical system (did eye up the "how to" for autodipping rearview mirror and heated seats but my wife said "no" firmly)
    Assume just plugging the traction control switch would be ok, or would it need tech 2 to tell ecu to turn it on?
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Yeah just a matter of plugging it in but its a bit hit and miss if it works some cars do others dont
    There have been a multitude of threads on it over the years mate, but I believe the consensus in the end was that if you plugged it in and it didn't work, then you're stumped. No amount of Tech2 etc will help it or make it work.
    I've got a 2007 3.0 Elite with every possible option on it, and it still doesn't work...
    It did however finish off the dash nicely as it was the only blank that was there...
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Lmao, ok, first find a switch................thanks for the help, peoples, much appreciated
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
