Thread: Gearbox Oil.
    Full Member spennny's Avatar
    Blantyre
    Default Gearbox Oil.
    Gonna change it this week, whats the recommended amount,
    was it 2.4 ltrs
    And what type do i use for a 2.2 direct
    Blantyre
    bttt
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i believe it is 2.4lts for the 6speed F40 gearbox.. the oil is 75w-90 semi synthetic (about £9.96 a litre) or Castrol SMX fully synthetic (£12.99 per litre at Halfrauds)
    Will be doing this very same job this weekend and was looking into it today.. Most recommend changing the drain plug but some have re-used them, they are only a £2.75+vat from the stealer P/N 11092271
    gear oil from VX is £4.75 per litre, could not get specifics of it as the vx parts guy was a flammin muppet..
    Blantyre
    Changing the oil do you think it makes any difference ?
    Jun 2009
    South Coast
    well some say it does.. I am about to do it, as i want to see if it resolves a noisey gear change.. When i did it on my Supra it made a world of difference, but the synchros were a bit shagged in that one. I am going to be using fully synthetic SMX all my local stores have sold out, i have 2 litres just need another one to start the job... In theory gearbox oil is supposed ot last the life of the car/engine but we know that the 3.2 litres they left the factory with is now wrong and 2.4litres is recommended. So in the process of changing and doing a one off job why not put in better stuff and see what you get after....
    Ljubljana
    HY
    i recomend to not to change your oil cause i have very big problems at the moment cuz of it. If you are not taxi car, dont change it it will ruin your gearbox. I was told so, that gearbox oil is lifetime, and they do not change whole amount, they change only from one chamber. The rest (major part) remains in gearbox.
    If u have some super mechanic let him change you the filter inside the gearbox and then change the whole amount.
    I have a problem cuz my signum not shifts right cuz oil mixed (old and new) and viscozity is making a trouble now.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    They are talking about manual transmissions buddy
    No filters in them
    Ljubljana
    OOOps sorry , i wanted to help... i didnt read well, sorry again
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Easy mistake to make
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
