Thread: Which Bulb?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Which Bulb?
    My front left headlight is off but not sure what to look for in Halfords? Also engine management light is on, is the only way to get rid of this by Tech 2? Thanks
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    H7 for main and dipped beam on pre-facelifts... you could try disconnect the battery for a bit, see if that clears it. not sure if it will work tho...
    May 2008
    Doncaster
    Quote Originally Posted by vectra 120 View Post
    Rather than using Tech 2 to remove it you'd probably want Tech 2 to diagnose the fault and then put it right! Hopefully it's just a sensor or something that's cheap to find and fix.
    Disconnecting the battery may get rid of it temporarily but I'm sure as soon as whatever put it on in the first place comes back it will be on again!
    thanks for the info are the H7 with or without gas discharged
    thanks steve
    http://www.halfords.com/webapp/wcs/s...d=&makeName=-1
    Regular Member LADmachining's Avatar
    Hampshire
    Gas discharge ones are for cars with Xenon dipped beam bulbs. You need the without gas discharge ones.
    Quote Originally Posted by LADmachining View Post
    Ok thanks all
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Has this affected the driveability or acceleration of your vehicle in any way?
    Quote Originally Posted by 123rado View Post
    Had a problem with no power two days last month but that was it need to get the code read a.s.a.p
    Steve
    bulb done thanks to all
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Steve
    The last time my management light was on, I was told it is the turbo hose. VX quoted £180 for it and they had to order from Germany. Bought the turbo hose myself and fitted (£57). I doubt if this could be the same problem but you can check the hose to see if there is any leak.
  1. Bulb kit
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 08:31
  2. Bulb Gone?
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2010, 22:24
  3. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  4. New Bulb Help
    By Pie Sharp in forum Styling
    Last Post: 16th March 2009, 10:24
  5. Bulb Fit
    By T4M in forum General Chat
    Last Post: 5th January 2008, 01:10
