Results 1 to 2 of 2
Thread: changing abs unit
    durham
    Default changing abs unit
    hi i have had confirmed this morning that my abs unit is goosed i have obtained a second hand unit. what i want to know is it easy to fit. there seems to be two bolts and six brake pipes. could i damage the unit, will the unit need coding to the car. cheers for any advice.
    vectra c 2.0 dti
    Regular Member LADmachining's Avatar
    Hampshire
    If the unit was removed from a working vehicle with the same engine as yours, it shouldn't need programming.
    They are a bit of a pain to fit. The control unit can be seperated from the valve block, but it is very difficult to do this in-situ without causing damage. Just bite the bullet and remove the brake pipes. Oh, and disconnect the battery earth lead before starting work.
  1. changing my head unit to a 2013
    By coolj in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2013, 03:35
  2. Changing head unit & TIF to GID or BID
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 01:17
  3. Changing ABS ECU unit
    By PhilDunford in forum Suspension, Wheels & Brakes
    Last Post: 11th June 2009, 13:22
  4. changing head unit
    By cr0m81e in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 10:26
  5. changing head unit
    By sph73 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2006, 16:44
