Results 1 to 2 of 2
Thread: 2.0dti Not Starting
    Newry
    Unhappy 2.0dti Not Starting
    Only recently joined this site and unfortunately my first post is a problem. I parked the car at work and when I came back to it late in the evening it wouldn't start. It's as if it's out of diesel or not getting any but there's half a tank full. After i tried it a couple of times i was getting a spanner light as well. Is there a checklist i should go through step by step to try and remedy this. Also is there any kind of temporary solution to get it going so I could get it home or to the mechanics if need be. Thanks in advance
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    If it was me,i'd check the leak off pipes first,to make sure they are not perished or split,these are rubber fuel return pipes fitted to the injectors going to the fuel pump.
    Then i would crack open the top injector pipe union nuts a little,one at a time and get someone to crank the engine over until i saw fuel,and tighten the nut back up,repeating on all 4 injectors,and then crank it again if fuel is coming out,and hopefully it should fire up.
  1. 2.0DTi starting problems
    By Davyturner in forum Engine & Drivetrain
    Last Post: 10th February 2013, 13:29
  2. Starting Problems 2.0DTI
    By danny1992 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 19:29
  3. 2.0dti trouble starting
    Last Post: 31st January 2010, 18:58
  4. poor starting 2.0dti
    By bertmarshall in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 10:50
  5. 2.0dti non starting
    By richc in forum Engine & Drivetrain
    Last Post: 1st June 2008, 22:01
