Results 1 to 10 of 18
Thread: Axle Weights so Close
    May 2008
    Doncaster
    Default Axle Weights so Close
    Hi All,
    I have a 1.9CDTi SRi 150 facelift Vectra and my axle weights are:
    1065 and 985 (front, rear).
    The springs LMF sell go up to 1060 then 1061 to 1130.
    Because of my axle weights I expect I should go to 1061 to 1130 but is 5KG really that much and will my car sit too high with the stronger springs on?
    What has everyone else done and have you had any problems?
    Cheers!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    iam not sure but that might be the max weight on a fully laden car
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    It is when fully loaded.. and yes you actually need to get the 1060 kg ones..
    May 2008
    Doncaster
    Quote Originally Posted by kenp View Post
    So you're saying the 966 to 1060 KG ones are right?
    If it's fully laden then if it's only me and the Mrs in the car then I assume the above springs will be fine?
    Cheers!
    Engine : 2.2 Direct
    yes but actually wont be legal..
    so i would go for the next level..
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if i doubt just give lmf a call, i am sure either steve or dan will put you on the right track
    Midlands Mod Shop - NFFC.
    Full Member Big Sig's Avatar
    1061-1130kg for yours imo, but rign them as rich has said
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Had a little discussion about this here. Considering the variation in passenger weight I can't imagine 5 Kg is gonna make any difference whatsoever and so really you have the choice of either and with a little expert help you will be able to make an informed choice......
    http://www.vectra-c.com/forum/showthread.php?t=104370
    May 2008
    Doncaster
    Quote Originally Posted by CHRISK View Post
    Cheers for the link, I guess I'm going to have to ring them on Monday to see what they think!
    5KG is less than a stone so I can't see it making much difference so if the Mrs gets fat I'll just get her on a diet and bring the axle weight down again!
    West
    1061+ kit is the right kit... if you get the lower weight rated kit, you wiil prob sit much lower on the front than the rear & could bottom out on bumps etc...
  1. Axle Weights - Add Yours Please
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2017, 09:32
  2. Axle weights
    By pipamish in forum Handling & Braking
    Last Post: 14th February 2012, 22:36
  3. Axle Weights
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2009, 16:48
  4. Axle Weights
    Last Post: 28th March 2009, 20:30
  5. axle weights
    By lizard in forum Handling & Braking
    Last Post: 10th July 2008, 20:11
