Results 1 to 10 of 28
Thread: On the spot fines for illegal tyres
    Regular Member marky2027's Avatar
    Northumberland
    Default On the spot fines for illegal tyres
    I have been telling my sister in law to change her tyres for weeks now as they are equal with the wear indicator. her hubby though is insistent that if pulled over by the police you are given 28 days to change them without incurring a fine and points. I am sure they can fine you there and then (3 points and up to £2500 per tyre). Which is right? (by the way I never let mine get below 3mm!!)
    Jan 2010
    Liverpool
    When the 28 days is up, the wear will be below the 1.6mm indicator. Albeit very slightly.
    It's on the spot points and fine. I'm sure of it.
    Tyres down to the tyre tread indicators may still be legal, as they are set to 2.0mm
    You need to make correct tread depth measurements (see the last section below)
    I tend to order my new tyres when the tyre tread indicators are finally level with the top of the tread
    It depends on the nature of how illegal the tyres are, hence a Fixed Penalty Notice cannot be issued, the matter has to proceed to court
    The prosecution case is PER tyre and so each tyre has to be referred to separately, although it can be dealt with in one case
    However, the officer can apply discretion depending on the remaining tread depth and general tyre condition
    Between 1.0 and 1.6mm the officer MUST issue a VDRF (Vehicle Defect Rectification); failure to comply with this will result in a prosecution
    Between 0.25 and 1.0mm the officer MUST issue a VDRF and the matter may still be considered for prosecution (even though the VDRF is complied with)
    Less than 0.25mm and the officer MUST issue a VDRF, but may also consider an immediate vehicle prohibition
    The measurements are taken across the central three quarters of the tread, so make sure they measure the tyre correctly (the first number of the tyre profile)
    Three measurements must also be taken, one from each of the opposite edges of that central three quarters zone plus one from the centre
    Northumberland
    I have been pushing her for weeks to get them changed!! I never knew the wear indicators were set at 2mm and not 1.6mm. I suppose this is to ensure in most cases the tyres get replaced before they hit 1.6mm. If issued are the fines payable within 28 days? is this where he is getting this figure from?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Show her this
    What Are the Penalties for Driving With Faulty Tyres?
    In the case of any vehicle, with the exception of goods vehicles and vehicles adapted to carry more than eight passengers, for every offence there is a fine at level 4 of the standard scale with discretionary disqualification with 3 penalty points.
    Level 4 currently stands at £2,500 and each faulty tyre is considered as a separate offence, which can really add up. Two faulty tyres equals £5,000 and 6 points on your license, and so on.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    told my sister about slick tyres she's had for a month.
    Northumberland
    Quote Originally Posted by mattv6diesel View Post
    Aye Lewis Hamilton would be proud of these tyres!!!!
    Jan 2010
    Liverpool
    Well, you learn something new everyday. Nice info.
    Northumberland
    Well she has listened this time and is now at Tyre Spot..God knows what brand of tyres she will end up with though!!! Thanks for all the advice
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Wrong, might be in scotland but its called the VDRS in England and the police don't need to issue one.
    Vehicles - Vehicle Defect Rectification Scheme (VDRS) Tickets
    A VDRS ticket can be issued by a police officer for certain offences relating to the condition of a vehicle, and are issued dependent on the relevant factors of the offence, at the officer's discretion. This gives the driver the opportunity to have the fault repaired, rather than be prosecuted. To avoid the possibility of prosecution, the driver must do the following within 14 days of the ticket being issued:
    • Have the vehicle repaired.
    • Have the vehicle inspected at an MOT approved testing station.
    • Have the VDRS ticket endorsed at an MOT test station to confirm that the fault is rectified.
    • Forward the completed VDRS ticket to the Central ticket Offices within the time specified on the ticket.
  1. on the spot fines for careless driving planned
    By Hideous in forum The 'Off Topic' room
    Last Post: 14th May 2011, 23:28
  2. Some decent fines at last for using a phone while driving
    By 67688c in forum The 'Off Topic' room
    Last Post: 16th February 2010, 01:09
  3. Speeding fines?
    By Andy79 in forum General Chat
    Last Post: 15th December 2009, 11:59
  4. Speed - what fines?
    By Small Racer in forum General Chat
    Last Post: 24th April 2009, 17:59
  5. Paying Fines..?
    By macdad in forum General Chat
    Last Post: 25th July 2008, 13:36
