Results 1 to 10 of 14
Thread: Should I have a trailer light....
    North East
    Default Should I have a trailer light....
    ....or not?
    I have just installed a westfalia tow bar with single electrics and the trailer module. When I have connected trailer/ caravan all the lights work fine but I have no driver indication that there is a trailer/ caravan connected. I was under the impression that its a legal requirement to either have a light on the dash or warning buzzer when indicating.
    Please can you tell me what you think......
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    probaly because it needs tech2 in.
    North East
    Quote Originally Posted by kenp View Post
    what does this light look like and where on the dash is it then, I cant find anything in the car manual about it at all.
    cambs
    Quote Originally Posted by lds1973 View Post
    HI
    Tech2 is a software program that talk to the cars computers and it can turn programs on/off, fault reading and general programing
    you will need some-one with the software like you local vx dealers or if any-one on here has one in your area.
    vx will charge you around £50-£70
    Engine : 2.2 Direct
    The indicator is self that you are turning with somthing on the hitch... is actually a "small" tobar indicating, in the lower right hand of the dash.
    Regular Member eaglepva's Avatar
    Up North
    when i tow a trailer and indicate, i get a buzzer sound.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by eaglepva View Post
    Only the plug in wiring kit can have the dash light
    Engine : 2.2 Direct
    then the OP needs tech2 in the IPC (is done in the REC otherwise it wouldnt work) and in the GID/CID
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    lds1973, Where abouts in the "North East" are you?
    North East
    Quote Originally Posted by tramman View Post
    Im in stockton...
    ...from what I can gather I just need the tech 2 ing so I can have the dash light, seems a bit excessive as it will be, what about £40 for someone to plug a communicator in. I think I will just leave it as it is and hope I dont get pulled by a very switched on plod.
  1. Trailer tell tail light?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2011, 12:45
  2. best ever trailer?
    By jimbovectra in forum Games Room
    Last Post: 20th March 2011, 01:55
  3. trailer indicator tell tale light. yes or no?
    By brotherkennyh in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 21:11
  4. trailer
    By Gripper in forum General items for sale
    Last Post: 12th June 2007, 17:58
