Results 1 to 10 of 14
Thread: Lowering Springs on SRi With B4 Shocks?
    May 2008
    Doncaster
    Default Lowering Springs on SRi With B4 Shocks?
    Hi All,
    If I got some lowering springs, I'm thinking Eibach but may go PI, would B4's be better than the standard SRi shocks?
    I heard that SRi shocks are shorter anyway but I assume B4's will be standard size and turn out to be longer than I already have?
    Should I stick with the standard shocks or go for B4's even if they are longer?
    I really want some B6's but that's way too much money on top of what the springs will cost.
    Cheers!
    WGAF#5
    indeed the sri shocks are shorter to accomodate the shorter/stiffer springs
    by fitting pi's or eibachs you will be lowering again by another 15mm minimum dependant on the kit your looking at - so the standard springs should be ok - the b4's would indeed be oem standard so could be longer - the b6's are definetly shorter and a vast improvement on standard (non sri) shocks
    hth
    regards
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    hth
    regards
    B4's and B6's are the same length shocks, its the B8's that are shortened
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by danBoy View Post
    Are the B4/B6's the same length as the SRi shocks or the non SRi ones..?
    Jun 2006
    Northampton
    As far as I'm aware the B4's are equal to the SRI shocks, but I've never put them side by side to measure them.
    Regular Member P3tchy's Avatar
    Milton Keynes
    When I oredered my B4's from Euros they wanted to know if they were for the Sports chassis or Normal, So I'm guessing they are the same as OE SRi ones cos with the -30mm eibachs springs its dropped about 40-45mm
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    the b4s were shorter than my elite shocks so think they are same as sri ones.hth
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by P3tchy View Post
    Is yours not an SRi....?
    Milton Keynes
    Yeah, SRi is 15mm lower than standard, -30mm eibach + B4's = about 40mm lower than it was. So I'm guessing the eibach were either 45mm ones or the B4's were meant for the SRi, i.e shorter than normal vec ones.
    Lancashire
    Trim : XP1
    Mileage : 66000
    The Eibachs are -30mm (-30mm over non SRi, so -15mm on SRi) and if B4's are the same length as SRI shocks (which are shorter than standard non-sri shocks) then it should drop -15mm - surely... (and I'm not calling you Shirley)
  1. Lowering springs and shocks
    By owen_999 in forum Handling & Braking
    Last Post: 17th January 2013, 15:51
  2. Can you fit just lowering springs but keep the original shocks?
    By signum_rob in forum Handling & Braking
    Last Post: 25th November 2012, 18:34
  3. Can you fit just lowering springs but keep the original shocks?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2012, 23:53
  4. lowering springs and shocks
    Last Post: 19th May 2010, 21:21
  5. Lowering Springs on Standard Shocks
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 01:51
