Results 1 to 10 of 14
Thread: 1.9 150
    Regular Member robk6112's Avatar
    Halifax
    Default 1.9 150
    Morning
    My 150 temp gauge never moved for the last 4 months. It has now suddenly started to work but the car feels slower under 2000 rpm? My egr valve has been done last year by the way. Any ideas? By the way I love my 150 and not here to slag it off!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Oddly mine has started to move recently, but its probably down to the fact I have the heater on cool now, rather than warm/hot - no difference in running though.
    Maybe your EGR needs a clean, alot can happen to them in a year.
    Swirls etc ok, a quick visual check will confirm.
    Regular Member P3tchy's Avatar
    Milton Keynes
    That will be the thermostate then, Needs replacing. and as soon as you do it will show up faults with the inlet manifold. Thats what happened to mine.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by P3tchy View Post
    Surely coincidence..?
    Halifax
    Ill get a new thermostat then. Inlet manifold have already had that done!
    Lancashire
    Trim : XP1
    Mileage : 66000
    Thermostat wouldn't make the car sluggish under 2k.... my thermostat been the same since I got the car and its been fine.
    Milton Keynes
    The inlet manifold has a water jacket after the stat, No idea why, Maybe Diesels are more efficient with warm air on the intake.
    If the stat won't open then the inlet will never get warm (neither will the inside of the car)
    Lancashire
    Trim : XP1
    Mileage : 66000
    My needle never (ish) moves, but still gets snuggly inside pretty quick... maybe mine has a dodgy temp sender then
    Halifax
    Milton Keynes
    If its for the 150 then yeah not bad, I paid £45 for mine inc vat. Theres a modified version but not sure on the part number. Just be careful your not buying old superceeded stock off ebay.
