Results 1 to 10 of 14
Thread: My 150 CDTI Veccy ain't going over 2,000 revs :( What could be the problem?
    Aug 2009
    Bradford
    Default My 150 CDTI Veccy ain't going over 2,000 revs :( What could be the problem?
    Hey guys
    Since yesterday, it shows up with a service light on dash and then doesn't rev over 2,000 revs. It happened yesterday whilst driving. I parked on the side. Turned the car off and on, it was all good then. Today just now, it did same again. Turned the car off and on about 3-4 times the car being off for about 5 secs each time made no diff. Drove to petrol station to check tyre pressure, turned the car off, checked pressure and back on and it was perfectly fine. What could this be?
    Also tyre pressure on standard veccy alloys and tyres ie 215-50-17, what should the tyre pressure be?
    Cheers guys
    Aug 2009
    Bradford
    Oh yeah forgot, the car has a Caterman chip box installed too. Can that make a diff?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    It seems to be going into Limp mode then.... could be worth removing the box and see if it stops, could be causing some fueling errors.
    Aug 2009
    Bradford
    Thank you very much Dan, I will give that a shot
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    The car and spanner light isn't a service light its limp home as mentioned above. (limp home is a secondary ecu program so the car runs on bare basics, no turbo, cruise etc to get home/to a garage) Could be a few things causing it. Best way is to get the codes read at the dealers and go from there.
    Also your tyre pressure should be on the tyre itself. I'd guess around 36psi ish.
    coventry
    from what i gather, the 150 cdti seems to be a heap. i looked on a google search "most unreliable car" and guess what???
    yeah, just got one in a zafira, DOH May have to stick with me 2.5 mgzt and pawn the vaux off to someone, yer not alone, they are cack!
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by Sums View Post
    Hey guys
    Cheers guys
    I have been getting this problem with my car,but i get it as soon as i slow for a roundabout after driving along for a few miles and go to accelerate from the roundabout again,i have checked the fault code and it has come up as P1109,which is to do with the swirl valves actuator.
    http://www.vectra-c.com/forum/search...archid=4569107
    I already have a new inlet manifold with swirl actuator ready to go on,as soon as i get a new gearbox
    As for your tyre pressures
    Saloon/hatch 1.9 cdti - front = 33 psi rear = 33 psi - with up to 3 persons in the car
    and front - 35 psi rear 42 with a full load
    Estate - front = 33 psi rear = 33 psi - with up to 3 persons in the car
    and front = 35 psi rear = 42 psi with a full load
    CHESHIRE
    Quote Originally Posted by stingy150 View Post
    its just a shame they're so unreliable because the first six months of owning this car and it was running how it should it was a plesure to drive, just a pity of the last two months running like a bag of s**t..
    Aug 2009
    Bradford
    Quote Originally Posted by Aikon58 View Post
    Thank you for the info The link aint working mate.
    @All
    The car is perfectly fine now, drove all day yesterday and no troubles. If it starts again, I will get the code read up and see what it says
    Aug 2009
    Bradford
    Quote Originally Posted by steve View Post
    I did check on the website about it but it stated the tyre size doesn't matter... the car and its weight is what determins the tyre pressure. Currently they on 32psi but seem bit low. Going to get them at 34/35 now.
    Thank you for help
  1. My CDTI 120 revs in to the red line???
    By Gibrunner in forum Engine & Drivetrain
    Last Post: 6th January 2013, 18:13
  2. Problem accelerating up hill...high revs
    By Kerr81 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2012, 22:54
  3. no power at low revs cdti
    By brownlow39 in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:39
  4. 1.9 CDTi (150) with no turbo and lumpy revs
    By Robsey in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 00:10
  5. Low revs problem
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2009, 17:40
vauxhall vectra not going above 2000 revs
