Results 1 to 10 of 15
Thread: cdti whistle help required ASAP
    Jun 2009
    notts
    Default cdti whistle help required ASAP
    My missus signum 1.9cdti, engine code z1.9dt, has started whistling on boost from about 1500rpm, reallly loud, there is a lackm of power and when i did get to 70mph(took its time to get there) the engine warning light has come on.
    Any ideas. Is this going to hurt my pocket? Warrenty runs out 28/03/10.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you checked the pipes leading to and from the turbo for splits?
    Jun 2009
    notts
    checdked all pipes I can see those from filter to turbo and then out of the turbo I loose the piping, then I find it again where it goes into engine.
    Where's the intercooler? I can see rad and air con rad. Can it be anything else other than piping?
    Regular Member kamar's Avatar
    bradford
    deffo a pipe mine did this on my previos bora tdi. also check intercooler as mine also went ant somepoint again on the bora and it was that loud that if i put my foot down people would look...
    Jun 2009
    notts
    I need to get it sorted asap. Go away sat and towing caravan with it. Vauxhall to look at it at 8am tomorrrow, but they going to diagnostic check it, possible MAF? don't see this being a cause, both me and ex garage mechanic couldn't see anything wrong, it is so loud and has so little power.
    bradford
    if turbo is loud im sure a leak or intercooler leak, check black if black smoke ur turbo pipe must av come off
    Jun 2009
    notts
    not really any black smoke, never is, even when reved hard
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It may also be a sign of turbo failure
    The intercoolers can split sometimes, it's inbetween the aircon rad and coolant rad
    bradford
    yep but i thought if the turbo was going it would go in limp mode, or smoke
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by kamar View Post
    Really depends how far gone it is, if it's just starting to go it could be noisy but still performing well. It would slowly start to deteriorate
  1. vec c mirror required asap!!!!
    By kojak01 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 22:16
  2. Suspension help required ASAP
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 19:30
  3. Oi filter help required ASAP!
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 3rd April 2007, 15:44
  4. Help required asap with wing mirrors
    By Matt21385 in forum Styling
    Last Post: 29th May 2006, 23:09
  5. Help required ASAP!
    By Matt21385 in forum Handling & Braking
    Last Post: 19th May 2006, 19:40
