Thread: Wiper Jets not spraying much
    Leicester
    Default Wiper Jets not spraying much
    Hi,
    first post...
    bought a vectra c 2.0 dti club on saturday.
    when i spray water on the front, only a little water trickels out,
    i thought it might be blocked but all four?
    any ideas?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    prob the washer bottle filter blocked up, inner wing passenger side, take out motor clean filter and bob's you nob
    Midlands Mod Shop - NFFC.
    Regular Member doughy's Avatar
    Jan 2010
    Wisbech, Cambridgeshire
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    Buy some Insignia jets from ebay for about £5 , makes all the difference and easy to fit. Spray covers most of the window and its better than those old jets.
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I had exactly the same issue lately.
    As has already been suggested, it could well be the small rubber filter that the actual pump pushes/fixes into on the bottom of the reservoir. Certainly was at the root of the problem in my case.
    As ditchp has already said, just remove the torx screws at the front of the plastic wheel liner at the passenger front wheel, pull the liner out the way a bit, and the pump should just pop up out of the rubber filter. Just prise the rubber filter out and give it a good clean.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    same happened to me i just cut the filter off and no more probs 10000miles on but up to you
    11 Post(s)
    Quote Originally Posted by puppet View Post
    Ah, that's where I've gone wrong. I thought the filter was part of the motor/pump assembly and gave that a good clean out. I didn't realise I had to pull the lump of rubber out the bottle as well.
    It has helped matters slightly though. The washer jets worked strongly, it's just that it takes an age for any water to actually come out.
    attleborough, norfolk
    have you checked that the jets are free of the plastic moulding? this happened to me. I must have leant on one of the jets and pushed it inside. if so, ping it back out with a screw driver.
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    dont use washing up liquid in yer reservoir bottle either, I did and it "split" after a few weeks and the washing up liquid turned to jelly and blocked the pump and tubes.
    run hot water thru your washer system too, you may have algae growing in yer tubes.
  1. Problem with wiper jets
    By Kenny_Exclusiv in forum Bodywork & Interior
    Last Post: 8th May 2012, 18:23
  2. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  3. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
  4. Wiper Jets
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2005, 12:01
