Thread: Dodgey GID Screen
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Default Dodgey GID Screen
    Hi All,
    Possibly more for folk who do screen mods etc...
    Well as the picture shows, I have a GID (Monochrome Graphic Info Display) with alpha code DD (Full Can pre facelift) 54 to 55 plate vehicles.
    The problem I have is that I am getting a light coloured swirl effect upon my screen...I am assuming that something internal is going AWOL.
    The mark took approx 1 month to get to it's currnet state, and seems to get slightly worse each time the screen is used.
    I can still see everything quite well, but the mark looks quite cack!!
    If I look closely at the mark, the screen appears to have two layers.
    An illuminated level, between the led panel and the front screen.
    Then there is a front layer upon which all the text and graphical symbols appear.
    It is the rear illuminated layer that is tatered.
    The text / graphical layer is perfect.
    Does anyone have a simple method of repair (unlikely),
    or a donor screen section for sale, where something else is knackered such as the circuit board, so that I can transfer and solder the good donor screen panel onto my rather poorly display unit.
    Saves having to mess with Tech 2 etc...
    Any ideas or offers
    milton keynes
    Robsey screen is shot mate , good thing is you can take a half canbus screen and plug it in with a little bit of modding on the 2 white wires , it will be fine.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yeah thought as much,
    I knew that I was really looking for a donor screen, with a knackered PCB...one that someone had cooked the LED's on or something...
    Would be a lot cheaper than buying a working GID from ebay.
    I also knew that it would be yourself or Bigmac that would respond...being the screen guru's on the forum
    Also my GID is paired to my CD70 , but also to a car which was stripped and crushed before it could be tech 2 divorced...hence I don't know the relevant audio pass code to divorce and marry any new screen to!! (although I do have the original vehicle reg and chassis number, but that is more expense from VX to get an audio pass).
    Mar 2007
    North East
    As others said looks like the lcd is starting to go. You might be able to source just the lcd.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    No one got a GID with okay screen but fried LED panel or damaged main PCB then?
    The pcb section is no use to me...as stated above, I need to retain my current PCB as it is that, that is paired to my CD70 !
  1. Half screen to full screen,
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 01:13
  2. Dodgey Graphic Info Display
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2011, 02:40
  3. Steering Feels Dodgey
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2011, 14:01
  4. dodgey handbrake
    Last Post: 4th September 2010, 10:04
  5. Dodgey Bonnet Release...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 14:22
