Results 1 to 3 of 3
Thread: abs light
    Apr 2009
    berkshire
    Default abs light
    its getting late now so asking the pros just changed n/s/f bearing hub after dronning noise all went well but now the abs light is on why is this the car is a vectra c 02 1.8 will it fail mot with light on thank you all
    Apr 2008
    murton seaham
    i take it you used a aftermarket part like i did they are no good tried 2 and still abs light on ,had to get genuine part and abs light went off straight away ,tony
    Jul 2009
    The Rift, Cardiff
    An abs light not following the correct sequence, ie staying lit, will fail the mot http://www.motuk.co.uk/manual_340.htm Is the new abs sensor plug the same as the old one? I've read a good few posts about new hubs being fitted and the abs plug is slightly different.
    By Shadrack in forum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
