Thread: EGR info
    southport
    Default EGR info
    Hi could any 1 tell me on a 2.2 dti 03 egr whether i should be able to push the piston back by hand its the egr with the 2 pipe connectors on thanks
    steve
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    HI SPM
    the piston should be closed when you remove egr,have you cleaned inside ,the piston is closed with a spring when the electro magnet feed circuit is closed,also check inside inlet manifold it will probably need a good clean
    southport
    cheers jonny ,ye the piston was closed and ive give it a good clean but wounderd if i should be able to push the piston back to see if it was seized to see if it was stuck in the closed position .
    Jul 2009
    Engine : 20 Dti
    if you ease of the green plastic cover (be carefull lifting the plastic clips or they will break)it slides off,you can then turn the actuator hook and the piston will disengage from the piston,you can then clean piston and hook,make sure the steel roller is free,I use brake cleaner and a small wire brush on my dremell,put copper slip on piston shaft,hook ,and roller,job done.
    Jul 2009
    Engine : 20 Dti
    it sounds fiddley but it's ok,just be carefull as i say with the plastic lugs,use a small screw driver lift them one at a time and ease of cover
    southport
    thanx jonny will give that a go soon just need to get codes read somewhere cheap lol then try sort out my mpgs got it up from 32 to 38 on mixed mway and town after air filter and oil n filter change , thinking of tackling fuel next lol
    Jul 2009
    Engine : 20 Dti
    my Signum 2.0 dti doe's 43 to 46 depending how big your boot's are as a guide
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Just a bit of info here.
    if you have an op-com there is a section in there where you can test the EGR movement
  1. v6 info that might help
    By Critch in forum Y & Z30DT Specific
    Last Post: 18th February 2016, 14:20
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Hi all, new and looking for info - 2.0T!
    By hog in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:55
  4. just after some info
    By pricey797 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2009, 22:03
  5. 2.0T Info
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 15:39
