Thread: 1.9cdti juddering when started
    washington tyne and wear
    Default 1.9cdti juddering when started
    could anyone please advise me, I have a 56 plate 1.9cdti and have noticed today that its taking longer to start and when it does start Im getting a terrible judder/thump from the engine? if anyone can help it will be most appreciated.
    CHESHIRE
    could be time to replace your glow plugs what millage are you on mark..
    Aug 2009
    Bradford
    My dad told me if the car causes starting problem, it can be EGR valve as he had an Astra which did same problem. Once EGR valve was changed, it was all good
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Glow plugs!.
    Jul 2009
    county down
    mine does same - if there is a glow plug fault you will get engine mangement light, so forget that....I feel judder on cold start but VX can't find any fault - EGR been done, manifold been done, 1 glow plug changed - just learned to live with it, heard from someone it's a 'known issue' to VX on Z19dth.
    I personally believe it is in some way emission related as get fair bit of healthy smoke during judder.
    mars
    dont talk to me about EGR valve, im having mine replaced under warranty tuesday funny thing is the car runs like a dream with out a problem.
    thanks for help, i got it sorted today, had to change the battery as i was driving yesterday and the car came to a halt, when i tried to start it nothing! ive only done a few miles a day lately so i suppose it hasnt had a chance to charge! just strange for the battery to go like that.
    Regular Member LADmachining's Avatar
    Hampshire
    Vauxhall released a technical bulletin for rough running on start-up due to low battery voltage caused by the alternator not starting to charge until the revs are brought up above 1000rpm.
    It is possible your alternator is not charging properly, causing the flat battery and the running problems on start-up.
    Charging voltage should be at least 13.8 volts measured across the battery terminals with loads on such as headlights/heater blower on full/heated rear window, engine running at 2500rpm.
    CHESHIRE
    Quote Originally Posted by gaby19uk View Post
    ok ill ask the question ,why are they replacing it?
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Quote Originally Posted by LADmachining View Post
    I got the same thing for the last 2 months until today, when the alternator failed completely. So I think you might be right on all you're saying above. I will get back tomorrow after I repair the alternator.
  1. Juddering 1.9cdti
    By Alan/1967 in forum Engine & Drivetrain
    Last Post: 9th October 2011, 17:17
  2. 1.9CDTI Clutch Juddering
    By robdd1 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 21:00
  3. 1.9CDTI (150) Won't Rev When Started
    By robblue2x in forum Engine & Drivetrain
    Last Post: 26th November 2010, 19:18
  4. Help needed with 1.9cdti 150 juddering!!!!
    By stuart813 in forum Engine & Drivetrain
    Last Post: 26th May 2010, 22:36
  5. Juddering 1.9CDTi 150
    By ghostrider in forum Engine & Drivetrain
    Last Post: 11th September 2009, 23:44
1.9 cdti judder when first started
vectra c 1.9 cdti juddering when first start
vectra c 1.9 juddering start
2007 vauxhall vectra juddering
1.9 cdti juddering
whats causing my vauxhall signum 1.9 to judder badly when driving
vectrs c cdti not starting and running rough
1.9 cdti running voltage
1.9cdti engine judder
1.9cdti alternator low charge
vauxhall vectra 1.9 cdti sri juddering
vauxhall astra 1.9 cdti juddering when started
