Thread: Help With N/S/F- Centre Knocking Please
    Lincs
    Default Help With N/S/F- Centre Knocking Please
    I seem to be getting all my problems in the first month
    I've develeped a knocking, all of a sudden really, coming either from the n/s wheel or more central, i can't tell.
    On the open road at cruise, no problem, but on bumpy village roads she's really knocking. Sounds like some suspension bush, or somethings loose
    Is there a common area here i should be looking at?
    Cheers.
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    check the springs
    PRESTON
    yup, i bet it be a spring, i had a knock totally similar cricumstanes to yours, sounded it was comming from mid to o/s/r, turned out to be o/s/f spring had broken at the bottom and the loose piece was banging around,still attached to the plastic anti squeak insulator. Both fronts being changed sat.
    Lincs
    Thanks chaps, but i've ran my hand around the springs and can't feel/see any breaks. I've just been out in it again and it really does knock, but again no problem when cruising.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    anti roll link arm probably worn out
    Lincs
    Quote Originally Posted by mattv6diesel View Post
    Hiya. Would this just go from being ok to knocking within a few days?
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    I had the same noise on bad roads but smooth roads it went away so took it to the garage and they changed the front shocker bearings and now it been ok the noise use to be like a spring had broken.
    Regular Member swirl80's Avatar
    Jun 2009
    is this sort of thing claimable under vauxhall warranty? I'm getting a similar issue.....
  1. knocking
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2011, 00:29
  2. Knocking from under the car.?????
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 08:40
  3. can SOMEONE help with knocking...PLEASE
    By carper kev in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 12:47
  4. Knocking
    By ianuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 23:47
  5. Knocking from car?
    By ectraz in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2009, 14:52
