Results 1 to 10 of 15
Thread: Polishing Rear Lights
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default Polishing Rear Lights
    I have noticed my rear lights are a little scratched, as if by a sponge.
    Was looking at attempting to polish them.
    Whats the best way to do this? As i can imagine the heat from a Kestrel DA6 not being good for the lights, and doubt I have a suitable polish for plastic
    I dont mind hand polishing to tidy them up.
    Regular Member PauloMcGuinee's Avatar
    Jul 2009
    Milton Keynes
    I think when paint is polished it removes a few microns of the surface to smooth out the scratches and also lifts some paint into any smaller scratches to help hide them. With plastic you are likely to only make the situation worse as there is no coating or paint to be removed. I'd avoid it and if its really a problem buy a new set of lights.
    The only other thing I would consider is wiping them down with alcohol based solvent and then spraying them (remove them from the car first of course) with a clear lacquer or if you are being adventurous mix a colour and lacquer together to colour code or tint the lights. But there is no easy solution - other than replacing them
    Regular Member P3tchy's Avatar
    Milton Keynes
    Meguirs plastic polish, specially designed for this.
    Jun 2009
    Norwich
    I use normal car polish on a machine polisher works a treat.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by P3tchy View Post
    PlastRX i think its called, great stuff
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    No problem polishing them with a DA whatsoever.
    Just use a small spot pad if you have one and a light cut product such as Megs #83. Finish off with a wax or glaze of your choice.
    Paul.
    Snowman, you got your ears on?
    Nottingham
    altho i have a DA I have never actually used it lol.
    A friend of mine suggested toothpaste :S bit old school i guess.
    Check my local shops for both PlastRX and Meguirs plastic polish
    Cant seem to find either :-( and smallest pad i have is 3.5 inch
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Lol its called Megiuars PlastRX buddy, they are the same thing
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Don't laugh but Brass polish on a wet cloth then buff away. Used this method on caravan window and took away really but scratches.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    meg's plastx is no longer sold iirc....i do have some though nick if you want to nip in and get some ???
    Midlands Mod Shop - NFFC.
  1. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  2. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
