Thread: Sump Plug - Oil Change
    Regular Member Sparky67's Avatar
    West Mids
    Default CDTi Sump Plug - Oil Change
    Thought a new thread title on here would be useful for people searching for CDTi sump plug problems...
    Having just had the car off the road for much longer than I expected for a simple oil/filter change my advice is:
    • Try using a 1/2" socket to remove it. 13mm can be a loose fit.
    • If you have to use a 13mm socket, particularly a 12-sided one, buy a replacement plug and washer first... Six quid something well spent.
    • If it hasn't been out before it might be be b tight and a b to remove.
    • When refitting don't crank it up too much.
    Or take it to a garage
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Or if you have a DTI like mine use a torx
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    10 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    My GSi was a torx too. I think they were used interchangably - maybe. Mine was no problem. Lucky, I guess.
    I bought a spare before I took mine out, though - £4 at a local motor factor, washer included! Bargain!
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Full Member paul.sessions's Avatar
    leighton buzzard
    Quote Originally Posted by GSiFan View Post
    me too got to do mine sat. sump plug and washer from vaux world £1.11 woo hoo
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Oil Change/Sump Plug
    By Mark-R in forum Engine & Drivetrain
    Last Post: 12th May 2012, 16:16
  3. One sump plug or two on a VVT.
    By disco dan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 18:36
  4. sump plug
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 11th June 2011, 14:20
  5. Sump Plug
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 18:55
