Thread: Vectra C 04- Engine Fault
    Canvey Island
    Default Vectra C 04- Engine Fault
    HI All
    Hope everyones doing well, this is my first post!!
    I have a 1.8 LS Petrol 2004 Vectra C
    The last month ive been getting a constant on & off problem. Every now and again in revs between maybe 1 - 3 the car will feel like it is being pulled back, and even with the foot down it is very laggy and doesnt want to go anywhere, then it will get to a point and go and the light comes on. Then after a while the light will go off and it will be ok for a while, then it all happens again.
    Does anyone know what this could be , and if there a cheap ( ???) diagnostics place to find out the fault and get it sorted.
    Many thanks
    Neil
    WGAF#5
    you can read the fault code yourself with the brake pedal
    with your foot firmly on the accelerator and brake pedal turn the key to stage 2 (lights on dash) and watch the engine light in the bottom right corner it will start to flash, then stop flash again , stop flash again stop and flash again a total of four sets of flashes
    10 flashes -= 0
    1 = 1
    2= 2
    and so on
    you should then have a 4 digit code to work out the problem
    hth
    regards
    Dez
    11 Post(s)
    It doesn't however work on every Vectra
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    if the hesitation feels like a slight missfire its very likely to be the coil pack (about £60) but i would try a set of plugs first
    Canvey Island
    Hi All,
    I done it on m,y Lunch break and it worked. I have
    10
    3
    10
    4
    Can someone point me in the right direction to finding out this fault please
    Neil
    WGAF#5
    P0314. Single Cylinder Misfire (Cylinder not Specified)
    as above possibly coil or spark plug related
    Canvey Island
    Thanks for your help on this, at least i have a rough idea of the problem when i take it in, it needs a service so ill get it all done in one go.
    This problem i have would it affect the fuel consumption??
    Ive only had the car about 6 months , but a full tank £60 and im just about reaching 400m, or is this the norm?
    Thanks again
    Neil
    WGAF#5
    a misfire would mean the engine is not running at optimum performance and as such would affect your fuel consumption.....
    i wish i could get 400 miles to a tank - i'm closer to 230-300
    Canvey Island
    lol, so im over reacting then!
    Ive moved from a fiesta 1.25 where £30 would get me 300 miles..
    Thanks again for all your help0, ill get the service done first, if the problem persues ill look at the coil pack
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Quote Originally Posted by Riches View Post
    Hi All,
    10
    3
    10
    4
    Neil
    P0304 - Cylinder 4 Misfire Detected
    Youll find all the codes here
    Personally i would try a set of new spark plugs first, much cheaper than a new coil pack. I got some Bosch Super 4 plugs, fitted them & got a misfire, which was confirmed by using the fault code reading method you used. I thought i would be buying a new coil pack, but put the original plugs back & the misfire disappeared, although it took a few days before the emissions light went out.
    I too have got a 2004 LS. I usually get around 400 miles to a tank full but that's some dual carriageway & motorway driving and some urban 30mph driving too, probably normal, but i have got the short SRI intake & have done the airbox mod.
  1. engine fault please help
    By neill in forum Engine & Drivetrain
    Last Post: 7th August 2011, 06:28
  2. 2.0 dti engine fault
    By huddsy in forum Engine & Drivetrain
    Last Post: 8th April 2011, 21:36
  3. Engine Fault?? Need Help Please !!!
    By bigpaw35 in forum Engine & Drivetrain
    Last Post: 6th August 2009, 21:47
  4. Engine fault ???????????????????
    By tony24 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 18:11
  5. Engine Fault
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 13th December 2005, 22:08
