Thread: Clutch Pedal!!
    Cheshire
    Default Clutch Pedal!!
    Hi guys, my clutch pedal has started sticking part the way down when i take my foot off the clutch! it doesnt happen all the time and the clutch is not slipping!
    does the clutch have a spring on it?
    Thanks in advance for any help!!
    Andrew
    Regular Member old cruiser's Avatar
    slough
    Could be that the original spring has snapped mate and is quite a common issue, there is a clutch spring mod' as it were of which you can purchase form vx dealer it is a spring piston affair and isn't too bad to fit and that may well solve your problem.
    Cheers Pete
    Apr 2008
    murton seaham
    mine has started creaking near the top the clutch just before you lift your foot off do you recon it just needs oiling or a new part ?
    slough
    Quote Originally Posted by tonyord View Post
    You could try just oiling it mate and see what happens,at least that's what I would do to start with, also does your pedal return to the top of it's travel as it should?
    Cheers Pete
    Apr 2008
    murton seaham
    yea pete it returns to top ok just creaking ill put some oil on it and see how it goes ta
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. clutch pedal clicking
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 18:58
  3. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  4. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
