Thread: rippled discs
    doncaster
    Default rippled discs
    hi you all,just had tyres fitted to the back wheels and the mechanic told me there was a prob with my discs .he said that it looks like they have not been contacting correctly.i mean if you look at my ndiscs they look like they have not been working properly and it is like looking at a flat pond with ripples on if you know what i mean.went to dealers and told them caus 08 plate and still under warranty,stealers say only covers callipers and components.cannot understand what could have caused this.going to stealers on saturday but got to cough up diagnostic charge until they can diagnose if it a fault by the callipers.hopefully it is .any body got any ideas what it could be before i go to stealers .sorry forgot it is on both sides virtually identical sides which sounds very strange to me ,i dont hink it could be the discs or pads could it .thanks and i hope you can give me some good vice to take to the stealers
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    rust has hot into the disk metal but just a gess. pics?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Not exactly sure what you mean by rippled , but if its ware rellated then they have possible been binding. And this has overheated the disc,s and warped them.
    doncaster
    i know pictures would help but both sides nearly identical very rare would you not think.and i mean it is not just one ripple there must be on one disc about 12 or 13 ripple s at about 1/2 mm in height all the way down the discs.and they are rusty not clean and shiney like the front ones which i would of thought they would be .i know that they dont break as much as the front but they should still be shiney would you not say .one side i could slightly understand but not both .try ang get some pics but need help without pics for now ,thanks
    doncaster
    i dont think they have been working .if you think of a round pond and splash in the middle you can see the ripple effect ,hope you understand a bit better.dont think they have been binding has they are not shiney
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    it tends to happen when cars are parked on forcourts for months the braking heat and lack of use causes poor wear
    doncaster
    not been on forcourt long has i bought it before it went on.saw it down the btm awaiting prep and made a deal with dealer so not been stood.also done 35,000 miles so been used frequent,so sorry hope this helps a bit more .
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    ? don't know then sorry
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Difficult to say for sure without seeing them. From what you describe it sounds as if both calipers have seized, unusual but not impossible.
    3.2 v6 Signum and loving it
    Worcs/Staffs/Westmids (ish)
    It could be that the car has simply had a hard life, constant heavy braking or riding the brakes causing heat to build up and warping the disks.
    Parking up on the handbrake after heavy braking will also damage the disks as the heat is transferred only into small part of the disk (the pad contact patch), this expands, the rest does not and when it all cools down the disks will be irreparably warped.
    Either way, the pads then wear inconsistently and over time form grooves is the disk which causes more heat and it's then a vicious cycle.
  1. new discs
    By sristeven1 in forum Quick Photo Album
    Last Post: 24th September 2010, 19:30
  2. new discs
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 02:22
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
  4. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
