Results 1 to 10 of 11
Thread: 2003 2.2 ls missfire
    crowborough
    confused 2003 2.2 ls missfire
    Hi can anyone help i just bought a 2003 2.2 ls with 135000 miles on the clock but it seems to have a fault it starts fine and drives fine for about 30 miles then it just starts to missfire badly, the traction control and abs and engine lights all come on but if i stop and turn engin off for 10 mins it clears for another 30 or so miles anyone have any ideas please.
    11 Post(s)
    If the fault lights are coming on, then get the fault codes read out.
    Mind you, if the ABS, TC, etc are coming on, it might be worth checking that your alternator isn't overcharging the battery.
    crowborough
    Thanks Dave will get them checked out i have just been told by the guy i bought it from that the drain hole by the polen filter was blocked and the car got wet inside just wondering what else got wet in the process and if this could have anything to do with it ?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Only the heater gets wet mate, and they do pack up because of water ingress.
    crowborough
    The heater seems to work ok apart from the fan only works on top speed.
    Quote Originally Posted by lplate View Post
    The resistor pack has been killed by the water ingress, thats why it only works on speed 4.
    crowborough
    Is that easy to replace or am i better off putting up with it that is as long as i can cure the missfire lol.
    crowborough
    Just read the thread on replacing the resistor first job on the list after missfire.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I can't think why the ABS and TC lights would be connected to a misfire? First off, try the cheapest, the plugs. Then on to the coil pack, and while the battery is disconnected get the ABS plug off and give that a clean.
    crowborough
    Im going to get fault codes read tomorow then hopefully will get a better picture will keep you updated.
  1. 2.8 Missfire
    By Ziggy in forum Engine & Drivetrain
    Last Post: 27th June 2012, 20:07
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  5. 1.8 missfire.
    By 16vVec in forum Engine & Drivetrain
    Last Post: 19th September 2008, 20:02
