Results 1 to 10 of 14
Thread: car radio in safe mode
    ebbw vale
    Default car radio in safe mode
    My radio is displaying "safe" i have entered the code several times but nothing seems to happen has anyone any ideas of how i can get my radio to work please????
    i keep talking to myself on my journeys to and from work he he
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    It musnt like your taste in music
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd have to guess maybe you're not entering the code using the correct procedure?
    The common one seems to be:
    Ignition on... switch radio off..... press and hold AS and switch radio on... wait for beep.
    After beep display shows something like 'Safe 10 - - - -'
    Enter code using number buttons 1-4 to cycle through each number position - keep pressing button 1 until correct number is displayed in position 1..... then button 2, etc, etc until correct code is shown.
    Press and hold AS until beep.... radio should then burst into life assuming correct code was entered.
    If it's not a code entry problem there may be a communication fault between the head unit and the car ECU ie the car thinking it has the wrong head unit fitted.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Handyandy-UK View Post
    Or its not the oe one so the code is incorrect?
    ebbw vale
    thanks i just managed to get in on to safe 10 and i entered the code on the car pass though it failed so i tried it again and it failed again i then tried entering the code which says security code as before hand i was entering radio code????
    still hasnt worked!!!!!
    im left on safe7 now and my luck is running out!!!
    i will try again in the morning because it wouldnt have any of it after the third failed attempt!!
    thanks for you r replys
    Safe 10 means you need to wait longer before trying it again, but for it to count down you need to leave the ignition on.
    Before you lock it for 24 hours, read the manual mate.
    ebbw vale
    im a lady!!! not at all good with cars sorry, plus i didnt get a mannual when i bought it back last year .... so this place is my only hope.....
    ooops sorry
    Safe 7 means its not going to let you enter a code for another 7 mins - 7 mins with the ignition on.
    The more times you enter it wrong, the longer it makes you wait.
    ebbw vale
    ok thanks ..... im gonna give it another go before i hit the sack!!!
    On the car pass can you PLEASE tell me which code it is??
    is it radio/code **** / ****
    and i need to enter the second part???
    off to newcastle on a hen weekend and need the radio for the journey from s wales
    Cheers for cooperating with a welsh gal heh he he
    Regular Member TonyJames's Avatar
    Sep 2009
    northants
    Its the 2nd set of 4 numbers (code)
  1. Radio gone into safe mode???
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 15:05
  2. radio in safe mode - no "beep"
    By dcb in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 22:26
  3. vectra-B Car400 Radio in Safe Mode - Unlock with op-com?
    By Innes in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2010, 12:47
  4. Safe mode
    By tomo610 in forum Diesel Engine related
    Last Post: 25th September 2010, 18:00
  5. safe mode
    By magpie27 in forum Engine & Drivetrain
    Last Post: 17th March 2009, 13:42
vectra c radio safe mode
display safe on vectra radio
vectra c radio
how to resync vectra c radio
vectra c radio safe
vectra safe mode
vectra c radio in safe mode
vectra radio safe mode
vectra c radio code safe
vectra c radio safe mode lock time
vauxhall vectra c radio was working when switched car off went to start car again and now in safe mode
car radio safe mode not beeping when pressing as
vauxhall vectra c radio safe mode
safe mode opel vectra
how to get safe off vectra radio
how to take safe mode off vectra c
opel signum radio safe mode
vectra c stereo safe mode
how to get safe off my radio Vauxhall
vauxhall vectra safe on display
vectra c safe mod
