Hi all, I've spent the last couple of days reading through the all the posts on here and I'm still not sure about what fluid to use or even if it can be changed?
This is the 6 speed tiptronic box fitted to facelift models. From what I've read on these forums this is the aisin warner AF40 box which requires 3309 spec fluid only. Local Vx dealers dont know much about it and told me fluid was £68 a litre - yes £68!!! then when I said it was an AF40 they said maybe it's £8 a litre then?
But they also said i could not do the job myself as the car has to be hooked up to their diagnostics and running at a certain temperature while the box is drained and filled.
I'm not sure I could trust them to use the right fluid anyway!
Anyone got any experience with this??
