Thread: Finally happened
    Sep 2009
    Glasgow
    Angry Finally happened
    Noticed loss of power from yesterday, didn't have time to look. day off today had a good look about engine and guess what SWIRL VALVE BAR haning off will phone garage tommorow, i have there 2 year waranty, ill keep you all updated as to waht happens.
    Sep 2009
    Glasgow
    is it covered by arnold clark auto care waranty.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    hopefully mate good luck
    Sep 2009
    Glasgow
    hi all quick update, phoned uncle arnold services and told them that i has loss of power and the actuator bar has came off the swirl valves, and asked them is it covered by my 2 year auto care waranty. We need to see it first before we can decide but i have just told you what the problem is so the car is booked in for next thurday it's the soonest they had. Can anyone confirm this being done under waranty, went to start car this morning and it shuddered and a billow of white smoke came from the exhaust but it drove fine appart from the lack of power and starting her up again for the journey home it didnt judder this time and no smoke. Dont fancy driving it a week like this, i know some of you have covered many miles with the bar off. When i got home i set about geting the bar back onto the swirls nipples, ive heard its a fiddly job and takes a good bit of time to get it back on, but had a brain wave moved all of the nipples to the same position as swirl 3 placed the bar back in moved it so it was sitting upright used a chopstick in the hole on the bar and positioned it over the nipples and pushed each one home with a screwdriver took 2 min very easy only thing is there is forward and back motion on the bar as the holes have worn slightly or is this normal, took it for a spin and power has been restored don't know how long it will last but hopefully it will be fixed thurday.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    You might want to pop the bar off again just before you go to the garage since it's Arnold Clark and they may just fob you off that they could find nothing wrong!!!.
    Sep 2009
    Glasgow
    yep was planning on doing that, just didnt want to run about with it off.
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Yes had same problem at xmas so i put mine back on and guess what it came off. still had warranty with perrys but they would not do it so i had to pay cost a arm and a leg make sure you change the conrol box i did beacuse that was worn to. GOOD LUCK MATE
    dealers told me it was due to build up off carbon in the manifold ?
    Regular Member marky2027's Avatar
    Northumberland
    Just started thread on this mate and contribution from VX for new inlet manifold. Might be worth checking it out
    Sep 2009
    Glasgow
    cheers mate.
  1. Well it finally happened! Gear knob popped off!
    By Neve'o in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 08:39
  2. What happened to
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 20:08
  3. ooh well its finally happened .....
    By westwoodz in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2009, 22:31
  4. What happened?
    By JSYSH466Y in forum General Chat
    Last Post: 25th February 2009, 09:48
  5. Never Happened to me !!
    By silverhairedracer in forum General Chat
    Last Post: 9th November 2007, 19:17
