Thread: permanant live by glove box ??
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default permanant live by glove box ??
    is there a permanent live available in the fuse box by the glove box as i want to change my rear cig power socket to permanent power ??
    Otherwise ill have to run from the boot
    WGAF#5
    You should be able to take a pernament live off the battery,through the grommet behing the glove box (or if I remember correctly there is a permanant live somewhere behind the glovebox you can tap off)
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Normally, most people take their permanent supply from the rear electrical centre.
    See the how 2 for fitting a charge socket in the load area of a signum.
    Much shorter cable run to the rear charger / lighter socket in the centre armrest.
    Is there any reason why you'd prefer to go from the front dash, rather than the rear electrical centre, just behind the back seat (passenger side).
    shropshire
    Quote Originally Posted by Robsey View Post
    Its just i can see a pathway to the cig lighter from the front via the handbrake and gearstick cover... from the boot iv got to get under the seat and the carpet and im not familiar with that pathway
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    There are both always live and ignition controlled positions in the large fuse and relay box in the engine compartment. Just plug into an unused fuse position, but remember that only one side of the fuse position will be live as the fuse is used to bridge the space and transmitt the voltage on.
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Is the cig lighter Switch Live or Perm Live
    By jake.clay in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2011, 12:48
  3. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
  4. Were to take a switched live and a live from for a boost gauge
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 15:02
  5. Permanant live feed...
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2009, 01:15
