Thread: Aftermarket Upgrade for CDR 2005
    Bromsgrove
    Default Aftermarket Upgrade for CDR 2005
    Hi,
    I've just picked up a 54 Signum 3.2 with the CDR 2005 head unit and to be fair, this audio system is absolutely awful..
    The sound quality really is as bad as the radio in my wife's fiat panda.. (No joke..)
    I'm not looking for heart pounding 'drum and base' at ridiculous sound levels, but am looking for a system with good clarity at a decent volume.
    In my Vectra B, I did nothing more than add a JVC headunit and wiring adaptor to get reasonable sound quality from the speakers, albeit not much volume.
    In my BM 325, I fitted an Alpine headunit, with wiring converter and steering control adaptor to give amazing sound quality at quite heavy volumes.
    As you can see.. I'm not into ripping everything apart and fitting amps, subs and the like.. (I did put a powered sub in the back of a Vito van, but it was a van.. it needed it..)
    I'm happy to pay a bit for an upgrade, but the question is...
    What's my best option?
    Can I just get a new headunit with facia, wiring and steering wheel adaptors and use the existing speakers?
    Do I need to start replacing speakers in doors etc..
    If so, are door speakers direct replacements?
    There it is.. I need the simplest upgrade path available to me to give quality sound at decent volumes..
    Any help is appreciated.
    Regular Member PORKBALLS29's Avatar
    Epping
    Hello mate its strange cos i have a 53 plate siggy with cdr2005 and the sound quality is great loads of base and very clear. It may be your speakers that are no good?
    Oct 2007
    Shropshire
    It might be worth checking what is wrong with your current system, because the vauxhall systems are not to bad. Like PORKBALLS29 says, I would check your speakers first. Sometimes people fit aftermarket ones and when reverting the car to standard, do refit them very well. I have seen them out of phase, ones with dented or ripped cones etc...
    The cost of a reasonable speaker upgrade is likely to be cheaper than a a head unit, and you don't have the problems of steering wheel controls etc...
    If you are not prepared to take the door panels off yourself, why not get halfords to fit you some new speakers for you. It will either solve your problem or make it even better if you still need a head unit....
    Bromsgrove
    Hi,
    Thanks for these responses, i'll try and elaborate..
    Whilst the system pretends to provide a good bass sound, it's what I call plastic bass.. it's artificial.. It's usually due to a stereo trying to artificially enhance the bass, instead of having the outright power to provide true bass.
    This is why on previous cars a simple headunit upgrade to a 50w * 4 has worked a treat.
    On those cars the existing speakers have been sufficient to handle the power output from the aftermarket head unit.
    On cars where the door speakers were too small to handle any decent output, I found the door itself needed modifying to fit larger speakers, which is not something I really want to do on this car as it is in almost showroom condition.
    Also, the grills etc in the doors look like they're handling decent sized speakers anyway..
    I found this link to a remote adaptor..
    http://www.justkenwood.co.uk/car-aud...remote-adaptor
    I wonder if anyone has done an aftermarket upgrade on one of these units, who might be able to tell me any pitfalls they encountered..
    Thx..
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    when i had my cdr2005 the sound quality was great get this man some speakers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by paulvectrac View Post
    Yeah, I agree - my CDR2005 sounds mint IMO, I just miss MP3 !!!
    My Vec B from a few years ago had some awesome speakers too, didn't give as much bass as my C but sounded really well.
    Jan 2008
    NW - Cheshire
    On my old Signum I swapped my CDR2005 out for an Alpine head unit, had steering controls working.
    I prefered the sound on the alpine, also had more features including MP3, Ipod connectivity etc.
    I posted some pics and info here http://www.vectra-c.com/forum/showthread.php?t=81058.
    Rotherham
    Just been doing the same research myself to upgrade my CDR 2005 in my 2003 Vectra LS
    For a basic upgrade, New budget head unit (Sony, Pioneer, Kenwood, Alpine), Component front speakers, and coaxial rears fully fitted with adapters, facias and sound deadening (needed as new system is more powerful and may cause rattles in the doors). Prices ranges from £350-430.
    If you want the steering controls add another £40-50 to that.
    If you fit yourself you can save £150-200 as it's about 4 hours labour.
    In the end I've bought the custom Pioneer Vauxhall Vectra front components and had my CDR 2005 repaired.
    I will fit myself.
    I don't have £400 right now to spend on a new system.
    Bromsgrove
    Quote Originally Posted by dennis_signum View Post
    Thx Dennis.. you're a star.. so if I get the right adaptors, I can drop an Alpine unit in with steering controls. Great..
    I too need Mp3 and iPod, i've also taken a nose at a double DIN from Kenwood today in Halfords which gives full iPod control..
    I'll post up when I've done to let folks know what difference I found.
    Thx everyone.
    Norwich
    Trim : SXi
    Engine : 2.2
    Got a CDR2005 in mine and can,t fault it for the sound been the best OEM stereo i,ve had in a car for a while and I normally always fit an aftermarket one
  1. Upgrade CD30 to CD70 or go for aftermarket?
    By saggybelly in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 19:51
  2. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  3. cdr 2005 upgrade?
    By JonSRi150 in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 21:46
  4. cdr 2005 upgrade
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 16:36
  5. cdr 2005 upgrade
    Last Post: 28th October 2008, 21:17
can i put a sub in my cdr 2005 vdo does it have aud in and out
changing my cdr 2005 vdo for a standard head unit
cdr 2005 vectra fitting trip
vectra cdr 2005 upgrade
signum cdr2005
cdr 2005 upgrade to cd70 what would i need
changing cdr 2005
cdr 2005 double din replace
