Thread: help plz
    Belfast
    confused help plz
    i drive a 120bhp cdti 05 48000miles on it, below 1800rpm my car is really sluggish but once the turbo kicks in the car goes spot on is there any reason for this?
    the problem seems to occur in lower gears, i had a hestitation further up the rev range but that seems to have passed
    all help welcome
    Brian
    Regular Member nigec's Avatar
    barnsley
    Start with egr valve and boost sensor as im haveing the same symptoms, just cleaned mine at weekend, make sure you clean the inside of manifold to where it bolts on.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like the EGR valve either needs cleaned or replaced
    Belfast
    sound guys ill have a wee look 2moro if i get the chance, i had it off not that long ago changin my heater plugs(nightmare) and it looked ok but ill get it off and have a look again sometime this week.
    Brian
