Results 1 to 10 of 13
Thread: Space Saver
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Default Space Saver
    Is there room for the space saver in my SRI boot to be replaced with a matching alloy to the standard ones on the car?
    yes
    but it sticks up a little bit higher,but nothing to worry about
    N E Somerset
    There is a sort of raiser under the space saver which takes up some space (at least there is in mine). Try taking it all out, jack up one corner and remove a wheel and see if it fits.
    Quote Originally Posted by bertxuk
    as last post it does
    like you said remove the raiser and your sorted
    ive got a 18 inch spare in my boot
    and as i said just sticks up a little bit
    Standard 17" will fit no probs m8ty i have put one in mine and Mrs D's veccy's
    Mileage : 000
    Not if it is an estate, there is not too much room to spare, so I look forward to where I can put the alloy if I get a puncture and the car is full.........
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    so why do they bother with a space saver when it doesn't save that much space. Tie up with tyre manufacturers perhaps??
    Dec 2005
    St Helens
    Manufacturers usually use space saves due to the independent rear suspension on new cars, as the struts meet in the middle directly under where the spare wheel well is, they have to strengthen it, which therefore usually raisers the boot floor, they then put a space saver in, to give the boot as much depth as possible.
    However why Vauxhalls don't put a full size steel spare in the Vectra Hatch & Saloon I don't know because they have the room to do it. I suppose it's for cheapness if they have to buy them for the estate they may as well use them for the full range and buy more of them to get them cheaper.
    I know a 16" alloy will not go in the estate, unless you remove the spare wheel cover, and then get some wood cut to size.
    It's a real pain the bum especially when you tow a caravan for over 3000 miles a year, if you where towing a caravan I don't think using a space saver would be a good idea, hence why we bought a spare alloy, and just put it in when we go on hols.
    May 2006
    yeah im sure putting all that weight onto a space saver would not be a good idea....
    In some cars you only get a can of Tyreweld and not even a space saver so i suppose we should count ourselves lucky :\
    Quote Originally Posted by S73VE B
    I only got a tin of tyre weld and a compressor in my Astra VXR, keeping the spare Vectra alloy for it though, it fitted in my boot space no problem, wouldn`t trust a space saver as far as I could throw it !!
  1. Space saver spare...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2009, 09:05
  2. Space Saver
    By cameraman in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 08:21
  3. Space saver spare
    By Robin in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 20:31
