Thread: MOT failed :-(
    Glasgow
    Default MOT failed :-(
    Well it failed the MOT today, i knew it would as my n/s/r spring has snapped but expected it to be replaced today BUT no they have'nt got one. So it will arrive tommorow, need to ask a mate for a lift to work now and then get him to take me to pick up the car lol.
    Its hell not having a car
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Get your springs upgraded, the rest will probably go soon. I have just changed mine for better ones
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    not so bad its only a spring you need
    Glasgow
    Im getting it replaced under a warranty i got with the car but a set of eibachs i will get eventually.
    Regular Member Readster's Avatar
    Plymouth
    good idea, get the MOT out the way first and that takes the pressure off
    Glasgow
    Thats my thinking
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Should be replaced in pairs as they could end up being uneven esp if the replacement spring is a copy and not original GM part
    May 2008
    saltburn-by-the-sea
    Angry Snap
    My signum (2006, 40,000mls)failed it's MOT due to a snap spring drivers side, so to that end as of December 2010 total costs of repair for my siggy is mounting up to well over a 1000 quid does it never stop numerouse problems with it rear bearings, erg valve and all fog light 55quid to replace nightmare my advice get rid I am
    p.s have this siggy form new been in vauxhall dealers 16 times for repairs NIGHTMAREEEEEEEE
    Northampton
    Engine : A20DTH
    Mileage : 88000
    SwannyOO you cannot blame VX for the broken spring its due to the state of roads and this issue also affects over car brands. Your EGR valve gunking up is partly down to the low mileage you are doing, I have done 130k in a 2005 car and never had any issues with the EGR valve. Again other car brands have the same issues more so on low mileage cars as they are not getting regular good runs which helps keep the Valve clear. What else has happend to your Siggy for it to go into VX 16 times?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    thats not to bad a failure mate. mot your own car i do
  1. Failed M.O.T
    By lanky659 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 10:39
  2. Failed MOT
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2011, 13:54
  3. EGR Mod failed
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 14:59
  4. Vec failed its MOT
    By JusSRi in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2009, 19:48
  5. Tried & tried but failed doing what?
    By Tadpole in forum Bodywork & Interior
    Last Post: 4th May 2009, 19:26
