Thread: Tilt sensor location
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Default Tilt sensor location
    As above anyone know where the tilt sensor is vec is a 2.2dti thanks Steve
    Also does the power for front ultrasonics travel from same line as intrior light so if lights getting power then ultrasonics should be or is it seperate ?
    Nov 2007
    btt
    11 Post(s)
    I wasn't aware the Vectra hada tilt sensor. No mention in the handbook or other blurb that's publically available.
    I would also imagine the feed for the ultrasonics is separate otherwise all a thief would have to do is snip the interior light wire to disable them.
    Nov 2007
    Yeah they have a tilt sensor all part of the alarm system. I Know the interior light and ultra sonics come down the same ribbon cable but if snipped it would go off as the car regualtes the voltage and a dip would set it off same way they cant disconnect battery to disable alarm. Just wondering if inside the ribbon cable they use same power feed. Or if there are two power feeds one for each. Anyone? Ta
    Edinburgh
    My ribbon cable is damaged at the moment (interior lights don't work & get "safeguard" message) I think they are seperate power feeds because to start with my interior lights weren't working but the ultrasonics were fine. Now neither work, I need to replace roof loom. Expensive bit of wire.
    Presumably if they accessed the car to cut the roof loom, it would set the alarm off and if they then snipped the roof loom, it wouldn't shut the alarm off, it would continue sounding.
    Nov 2007
    Thanks Big Knox sounds like seperate power feeds. was hoping it was! Cheers
  1. sensor location
    By stret in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 18:01
  2. Washer sensor pin location
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2012, 02:08
  3. crankshaft sensor location
    By thugusher in forum Engine & Drivetrain
    Last Post: 10th September 2011, 11:46
  4. Crankshaft sensor location
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 12:06
  5. boost sensor location?
    By chowwie in forum Engine & Drivetrain
    Last Post: 30th September 2010, 08:00
