Results 1 to 10 of 13
Thread: vauxhall radios?????
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default vauxhall radios?????
    can anyone tell me is there any diff between the cd30 and the cdc40 radios c/d players????? i have a cd30 is the cdc40 an upgrade or just the same but diff number????? cheers
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    CD 30
    stereo radio/CD player/six speakers
    (seven speakers on SRi models) (17 watts per channel)
    CDC 40
    stereo radio with Digital Audio Broadcast (DAB)
    facility/integral six-disc CD autochanger/graphic
    display/seven speakers (35 watts per channel)
    hope it help
    would i be able to swop over from a cd30 with out any probs or would i need any parts
    hinckley
    Quote Originally Posted by Thunder View Post
    CD 30
    CDC 40
    hope it help
    or.....
    cd30...... roooooobish
    cdc40.... the one to have.... or....
    ANYTHINGS better than a cd30 !!! hope i have not offended you.....
    Quote Originally Posted by studmuffin View Post
    or.....
    no you aint i want the cdc40 but is it a straight swop???????
    Jan 2010
    Middlesbrough
    Where is the 7th speaker?
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Quote Originally Posted by mitch View Post
    Will swap straight over(as long as both have been tech two'd out of the car first, only problem you will have is that DAB won't work without a new aerial.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Not all CDC40 have DAB. Only some do.
    If you have CD30, then you probably have the Triple Info Display, with the clock buttons on the bezel.
    The CDC40 has a Monochrome Graphic Info Display.
    For the most part it is plug and play. Just swapping parts (if it is non DAB).
    You may need 2 extra wires in the display plug to power the extra screen illumination / functions.
    There are loads of threads doing the rounds for upgrading to CDC40 with / without DAB.
    If you want DAB, then you will need the DAB box, the link loom and a DAB aerial.
    If your are really keen to upgrade, then look at these threads, or feel free to ask for help and guidance if required.
    WGAF#5
    Quote Originally Posted by 123yka View Post
    centre of the dash close to the windscreen
    Quote Originally Posted by Robsey View Post
    ive looked and cant see any buttons on bezel this is what looks like
    Attachment 30287
  1. Converter from FM to DAB for most OEM radios
    By Ralphwells1967 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 14:46
  2. When will FM signal end ? been looking at dab radios
    By Ralphwells1967 in forum General Chat
    Last Post: 28th December 2011, 22:00
  3. dab radios
    By titley1976 in forum General Chat
    Last Post: 16th May 2011, 16:00
  4. FAO Anyone swapping factory radios...
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 14:35
