Thread: Random Power Loss -
    Midlands
    Unhappy Random Power Loss -
    Hi, I have recently purchased a 54 1.9 CDTI SRI, it has had a new clutch and flywheel fitted recently, for some reason sometimes when i put my foot down the turbo doesnt seem to kick in and it sluggishly accelerates and other times the turbo kicks in, it flies! then turbo seems to go dead and then kicks in again? seems to be worse in the lower gears but it definately happens in all gears, I can hear the turbo winding so it seems to be doing its job and also ive got no warning lights or anything?
    what would be my best bet? is this a common problem?
    any help would be appreciated
    cheers
    Bristol
    Vehicle : CDTI 150
    Have a good check around the vacuum hoses especially to the turbo.
    Would also be worth giving your EGR and boost sensor a clean. See the How 2's on the site.
    Midlands
    thankyou il try that over the weekend
    Midlands
    btw what am i looking for around the vacuum hoses? and can i see the turbo from the top of my engine or do i have to jack it up?
    cheers in advance
    Bristol
    Vehicle : CDTI 150
    Check for splits, if you run your finger over the pipe you sometimes get a black sooty mark which can indicate the pipe is leaking. If you lift the bonnet and look down, between the radiator and exhaust you will see the heat shield over the turbo.
    Midlands
    Hi Guys, managed to fix it! it was the bit of the engine underneath the EGR valve, clogged up with lots of black stuff, the guy who did it for me also took off something on the right hand side 3 bolts and then used an airline to blow it out, hope this helps someone else
    Riz
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Have a look at the sticky thread on here for your vacuum turbo hoses and check these any way the stick is at the top
    of the page pics show you where they are hope this helps any ways mate
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Random power loss to headunit
    By Slammedorion in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2013, 11:10
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. Random Power Steering Failure
    By pauldellboy in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2011, 17:32
  5. loss of power
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 19:53
