Thread: cdti 1.9 not starting
    stevenage
    Default cdti 1.9 not starting
    hi all, wondered if anyone can help, the car isnt starting, it stalled on me last night, it seemed to take forever to start again , then this morning it wouldnt start atall. Millage 56'000 last 18 months the car has had, new intercaller, rge valve, new clutch, new autonator, i have noticed this morning that the bar along the manafold has come off, would this be the cause of the car not wanting to start? if anyone could give me any idea would be greatfull as im comeing to the end of my teffer with this vectra lee
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    If the swirls are stuck shut, then this could happen, can the 3rd one (the control valve) be moved by hand, to at least get it started I wonder..??
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    stuck swirl valves wont stop it from starting... Is it cranking over?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    stevenage
    yes mate its cranking over .got it started but it just takes forever to start' once its going its ok ??????
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    ah. ic. could well be inlet manifold/egr probs. Does it rev ok once started?
    stevenage
    yes mate rev ok once started can smell diesel in the car at times
    stevenage
    confused
    Lancashire
    Trim : XP NAV
    Swirl Valve issue as already stated, you really need to get it into a dealer/garage.
    The diesel smell could be injector seals, but is very likely to be the swirl seals have gone due to crud build up and is whats caused the bar to dislodge.
    stevenage
    got a new maniford today.getting it put on at the weekend.cheers for all the help
  1. 1.9 cdti {150} starting up
    By 1 hammer in forum Diesel Engine related
    Last Post: 5th October 2012, 21:34
  2. cdti 120 starting cold
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 28th May 2011, 22:08
  3. cdti 150 not starting
    By gazthebigyin in forum Engine & Drivetrain
    Last Post: 26th January 2011, 17:46
  4. V6 cdti starting Problems - new boy needs help
    By paul g in forum Engine & Drivetrain
    Last Post: 18th August 2008, 20:27
  5. Not Starting diesel cdti
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2008, 19:24
